Hello, I want to get into milling and am looking to buy a mini mill for around $2500US. I'd wondering what all a mini mill is capable of doing. I'm a newbie to this stuff. Will a mill cut all the way through a block or cut throught sheet metal or would I need a flojet or laser cutter? Can a mini-mill do something like this? I'm want to be able to mill copper and aluminum. Thanks! |
| $2500 is more the enough, I own a mini mill that cost £250 new and it can cut aluminium etc, Im sure you will be able to cut somthing like that with a mini mill, although you will probably have to cnc the mill to get somthing like that made. |
| Can you give us more information about the part? What is the size of the part and material? Without specifics, Two larger endmills to do the roughing and finishing. And two smaller endmills to rough and finish the details. Drills for the holes. Can use an endmill for the counter bores. And a good CAD/CAM system to make it all work |
| i think somthing like this would do the job you want : http://www.taigtools.com/cmill.html |
#11
| I think you should get the square collum lathemaster. 1500.00 Check it out, if you have the room, this is the best bet going. A big mill can make small parts, but a small mill cant make big parts. Good Luck! ( The Taig looks like a nice little mill, but I think youll be looking at a bigger one after a while. )
__________________ Halfnutz (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
#12
I want to thank all of you for your input and help. Great forum! Last edited by jl123; 05-13-2005 at 10:46 PM. |
| What size steppers for Grizzly mini mill? | Mini Miller | Benchtop Machines | 14 | 07-17-2005 11:45 PM |
| looking to buy a mini mill | Com | Benchtop Machines | 0 | 04-18-2005 01:51 PM |
| New to Mill and CNC - Can you mix a Mini and Micro Mill | Sherpa | Benchtop Machines | 2 | 09-09-2004 09:36 AM |
| Mini Mill - Ballscrew Z axis essential? | megavolt | Benchtop Machines | 5 | 09-07-2004 04:32 AM |
| possible cnc conversion on homier mini mill | WsW-WYATT | Benchtop Machines | 3 | 03-27-2004 07:24 AM |
