Results 1 to 7 of 7
Thread: My new 4th axis! And, my first post ...
    Apr 2010
    Smile My new 4th axis! And, my first post ...
    Well, here it is - Some photos of the little Vexta stepper, gear-belt pulley, the larger reduction gear, limit switch (every 360) and 5" bison 3-jaw chuck. The spindle housing is anodized aluminum and I has some NSK ball bearings in there. The chuck is mounted to a welded and painted custom faceplate with some plain old cap screws. So, here it is ... By itself, obviously ... I haven't quite picked out the medium-sized milling machine I like . Any ideas? Any comments on this little guy?
    Apr 2010
    Oh sorry! Right click and go to those images ...
    Registered Teyber12's Avatar
    Jul 2008
    edit* could not get re-upload to work sorry
    Dec 2009
    Quote Originally Posted by Wasteland View Post
    http://img59.imageshack.us/i/rotaryindexer007.jpg
    http://img412.imageshack.us/i/rotaryindexer006.jpg
    http://img17.imageshack.us/i/rotaryindexer005.jpg
    http://img30.imageshack.us/i/rotaryindexer004.jpg
    http://img202.imageshack.us/i/rotaryindexer003.jpg
    http://img413.imageshack.us/i/rotaryindexer001.jpg
    your pics arent registering at all
    Mar 2007
    Romeo, Michigan, USA
    Nice job on the indexer/4th axis rotary, Wasteland!
    I have a few questions on your build:
    Why are you using a limit swtich every 360 degrees?
    What are the details of your spindle? Is it just a tube that was made to mate with the bison 3 jaw chuck? or does it have an internal 5c, R8, 3mt, etc?
    What are the details of your gearing and reduction ratio? Did you make it a convenient division of steps? or of degrees rotation?
    Is there sufficient holding torque to keep the axis from turning during machining?
    Did you build a tailstock for the device?
    As you can see - I'm eager to build one...
    Thanks for any help that you can give.
    CNC-Joe
    [url]www.CNC-Joe.com[/url]
    CNC Is Not Just My Passion.. It's My Addiction !!!!
    Dec 2006
    Good questions CNCjoe, I would also like to add,
    WHat is the outer housing made off? And how did you get its shape like that?
    BTW, nice job. A good machine would be a G704. Ofcourse mediums size machine is a bit reletive to your own thoughts. What I consider a medium size machine may be bigger than what you think a big machine is.
    But as far as benchtop machines, the G704 is probably middle of the road, but still good ridgidity. A RF-45 makes a nice machine also but its starting to get up there in size, but no where as big as a IH mill.
    Jess
    GOD Bless, and prayers for all.
  7. #7
    Registered fragger6662000's Avatar
    Mar 2005
    UK
    i think you will have real issues with rigidity if you don't lock the axis and if that is the case then it negates the usefulness of the axis. i are you planning on making it into a spindle as well?
  1. New Machine Build- post for 2 axis ez trak versus 3 axis ez vision
    By tooolman in forum G-Code Programing
    Last Post: 11-28-2008, 04:33 PM
  2. 5-axis post
    By sidswiss in forum Surfcam
    Last Post: 07-01-2008, 02:00 PM
  3. Post Help For 5 Axis
    By ltmquik in forum CamWorks
    Last Post: 02-22-2007, 04:58 PM
