Page 1 of 2 12 LastLast
Results 1 to 12 of 18
Thread: Using my Micro Mill X1 as a lathe.
    Registered Arich0908's Avatar
    Oct 2009
    BridgePort , CT
    This is kind of hard to put my thoughts into words but ill give it a go.
    I currently own a Sieg X1.
    Can I mount a set of 3 jaws to my Mt2 spindle . And use it like a vertical lathe I guess you can say . I have a rotary table . What else would I need an adjustable tool post ?
    Is there an easier way to do this besides mounting a motor and pretty much a whole lathe set up on my bed.
    http://www.littlemachineshop.com/pro...63&category=10 And
    http://cgi.ebay.com/Taig-Tools-1050-...item335b8898e1
    Or
    http://cgi.ebay.com/ws/eBayISAPI.dll...:X:RTQ:US:1123
    This is threaded for a drawbar
    Oct 2009
    BridgePort , CT
    No one has done something like this?
    Registered knudsen's Avatar
    Feb 2010
    Hold the tool in your vise, and your all set.
    Rigging up a tool holder taller than your vise will allow you to cut a long piece. Vice mounted, or T-slot mounted, as long as it's sturdy and holds the tool tight. Simple to make out of a steel block. I've never done it, but it's been done before.
    Jun 2008
    Check out this youtube video showing a mill used as a lathe
    "http://www.youtube.com/watch?v=0hUEPfgKJwY"]YouTube- Cutting a switch knob from 6061 aluminum using a CNC mill as a lathe
    George
    Oct 2009
    BridgePort , CT
    For example Ide like to take a small square piece of aluminum lets say its 1 1/2 x 1 1/3 square and reshape it to a 1in circle.
    Cant I just stick it in the 3jaw get a tool holder and go to work .
    I realize I cant do this with a 6in 1foot long piece of stock .
    I want to make all metal gears for my X1 I figured I could do this.
    knudsen thanks for the tip ill try that.
    George thanks ill watch that now.
    Registered Teyber12's Avatar
    Jul 2008
    i tried this on my x3 and wasn't happy with the results...
    Oct 2009
    BridgePort , CT
    Quote Originally Posted by Teyber12 View Post
    Care to explain I cant see any difference at all. Its set up almost the same except one is vertical and the other is horizontal. Did you have the tool set correctly in the tool holder . From the way ive been thinking of it the tool wont dit the same since every thing will be flipped around.
    Please share with me so im not out wasting money.
    Registered CNCRim's Avatar
    Feb 2006
    check out this youtube video showing a mill used as a
    lathe
    [nomedia="http://www.youtube.com/watch?v=NzY-OqckqpI&feature=related"]YouTube- Machine4thAxisFinal - Time Lapse 2x actual speed[/nomedia]
    Feb 2010
    You are probably a lot better off starting with round stock. To cut gear teeth, you probably need to make a tool that spins in the mill spindle and use a rotary table to turn the part after each tooth is cut. Actually cut a valley, then turn the gear 360/no. of valleys. The tool to make is somewhat like a fly cutter, but the cutting tool is 90 degrees to the Z axis and is ground to the profile of the gear. You can just use the old gear as a template to grind it.
    You only need a $5 3/8" HSS tool blank to test the abilty to use the mill as a lathe. For short parts, as gears are, you should be able to just hold the cutter in the vise. What material are you planning to make the gears from?
    You might also check stock drive and mcmaster carr for metal gears. I've never seen an x1, would it be feasible to do a belt drive conversion?
    Jul 2008
    Quote Originally Posted by Arich0908 View Post
    I definitely did not do it super proper. But i chucked up some 3/4" steel i had into a 3/4" r8 collet. Then i used one of the teeth of a slitting saw clamped into a 3 jaw chuck. It would not cut in but the steel would just move away, which just marred the steel. I think it would be a different story if i had made a miniature gang tooling setup like you see in the video. I guess i should have elaborated.
    Cheers
    Feb 2010
    Probably would have worked if you used a proper lathe tool, but that is really cool how the vid has three tools mounted, especially for CNC.
    Using a mill as a lathe works better than using a lathe as a mill.
    It's better to make small parts on a big machine than big parts on a small machine.
    On the job, you can prick your finger, but you can't finger your prick.
    Floss daily, vote the straight ticket, you just might go to heaven.
    Oct 2009
    BridgePort , CT
    knudsen
    I was going to use my mill to cut the teeth .
    Ive never cut teeth before. This vid on youtube explains it very well.
    I was going to use it.
    Im not sure what metal ill use. I was going to use aluminum.
    I just seen the price for a Taig Lathe wow I didnt know they were so affordable for such a great product I may buy one very soon.
    "http://www.youtube.com/watch?v=62ymeJ0l9VM&feature=channel"]YouTube- Sherline CNC Gear Cutting Part5
  • Page 1 of 2 12 LastLast
    1. Mini mill X2 $359 at harbor freight - returning micro mill
      By Micro Milling in forum Benchtop Machines
      Last Post: 12-15-2009, 02:10 PM
    2. Need Help!- are micro-mark's mill and lathe good for CNC modification?
      By yang_cnc in forum Benchtop Machines
      Last Post: 05-06-2009, 01:42 PM
    3. Coming Down to the Taig Micro Mill or Grizzly Mini Mill.
      By SpeedsCustom in forum Taig Mills & Lathes
      Last Post: 01-23-2009, 12:14 AM
    4. Micro mill/router/lathe
      By jans123 in forum Vertical Mill, Lathe Project Log
      Last Post: 06-03-2007, 07:11 AM
    5. New Micro lathe built by me (my second lathe)
      By Stevie in forum General Metal Working Machines
      Last Post: 11-03-2004, 04:56 AM
