Results 1 to 7 of 7
Thread: Brass gibs
    Jan 2010
    Brass gibs
    I'm to the point with my X3 now that its cutting aluminum pretty well, but I'm pretty sure I still have some slop in my Z. I worked with a little steel yesterday and noticed some play in the head. The last time I adjusted the Z gib, I got it tight enough I had to lower my Z rapid feed down to 80ipm to prevent stalling.
    I've heard Brass gibs make a good improvement over the stock ones, has anyone done this themselves? Whats involved in machining the Gibs?
    Aug 2006
    I was in the same situation about a month ago. Like you, I planned on machining a brass gib and running with it.
    After getting the machine apart, I noticed just how off the stock Z gib taper was and decided to simply regrind the stock gib to match the dovetail.
    I am doing some other modifications to the column and haven't had the machine up and actually running yet, but sliding the z carriage back and forth on the column by hand, the results look promising.
    If you have access to a surface grinder, this is the route I would go. I set the vise off on gauge pins to dial in the taper. The taper should be .5* . In the end, I had to shim mine.
    Feb 2004
    Reno, NV
    Hi -
    I'm in the process of doing exactly this on my X2. See:
    http://cnczone.com/forums/showthread...=100770&page=3
    Beginning at post 85.
    ~Don
    Aug 2006
    One thing to consider is that the Z gib on the x3 is tapered longways. The y gib on the x2 is parallel longways.
    Jan 2010
    So i would need a bit more specialized equipment to correctly taper the Z gib. Sounds like something I probably shouldn't tackle on my own then.
    Are there any other options besides a DIY brass gib?
    Feb 2004
    Reno, NV
    I wasn't aware of the X3 z-axis tapered gibs. Good to know. I would think that if you have a working cnc conversion, you could do it pretty easily. If doing it manually, putting some thought to setup should allow you to do it. Tapering on a mill is angling the workpiece relative to the plane of the cutter. It's probably not very much of a taper. An indicator should be able to help you adjust it just fine.
    Do you have a drawing of the z-axis gib strip?
    ~Don
    Jan 2010
    I dont, no.
    I would like to see a drawing or pics of anyone else whos cut a new Z gib though. If I can rather easily clamp the brass stock and mill it to get the taper I might give it a whirl. I would need to find some brass stock.
    1. x2 Gibs
      By knudsen in forum Benchtop Machines
      Last Post: 03-02-2010, 02:01 AM
    2. HPDE Suitability For Gibs
      By pzzamakr1980 in forum Benchtop Machines
      Last Post: 06-04-2008, 06:09 PM
    3. Taper gibs vs Parallel gibs
      By Oldmanandhistoy in forum Linear and Rotary Motion
      Last Post: 09-08-2007, 08:25 PM
    4. surface grind gibs?
      By phantomcow2 in forum General Metal Working Machines
      Last Post: 06-11-2006, 08:10 PM
    5. Replace gibs?
      By cncuser1 in forum Benchtop Machines
      Last Post: 01-04-2006, 10:58 PM
