Results 1 to 3 of 3
Thread: How big a table do I need for a Sieg SX3?
    Aug 2007
    Denmark
    How much table depth does a Sieg SX3 require? What's bare minimum, and what's preferred?
    I'm trying to find out if a Sieg SX3 will fit on my existing workbench, which is approach 1'10" deep (61cm which is the standard kitchen counter depth in Denmark), but neither siegind.com nor any other website I've looked at state the "base area" of the SX3.
    I just want to make sure it can actually fit where it's intended, or at least used there until I get to make a better sized workbench.
    Jan 2007
    I just measured mine, and I think you would be pushing it but it might be able to be done. The base that Syil sells is 21" deep, but from the back of the machine to the front of the machine is about 24".
    Hope this helps.
    Wade
    Quote Originally Posted by strandbygaard View Post
    Aug 2007
    Denmark
    Thanks for taking the measure.
    I think I'll give the new workbench a little more priority :-)
  1. Sieg SX4
    By thebowman in forum Benchtop Machines
    Last Post: 05-11-2010, 11:32 PM
  2. open table vs closed-table gantry setups
    By nicanor76 in forum DIY CNC Router Table Machines
    Last Post: 04-21-2008, 01:35 PM
  3. XY table design basics, linear ways to table size ratio?
    By Konstantin in forum Mechanical Calculations/Engineering Design
    Last Post: 03-13-2007, 01:21 PM
  4. SIEG rotary table retrofit
    By ints99 in forum Syil Products
    Last Post: 12-17-2006, 12:11 AM
  5. Sieg X1, X2, X1L true table travels?
    By boom in forum Benchtop Machines
    Last Post: 11-01-2006, 06:34 PM
