Lots of stuff here.
I have a RF-45 type of mill and I adjusted all the play out of the table X leadscrew nut and did some milling with the power feed and an hour later I had .004" of play in the nut.
The nuts on the RF-45 type of mills have a crappy backlash adjustment system so you will have a hard time keeping the backlash low. I would remove the nut and at least cut the slot deeper so more of the thread would adjust rather than just 1/4" of it.
LinkBack URL
About LinkBacks
