Results 1 to 4 of 4
Thread: Serious Sherline/ EMC2 problem: Inverted axis
    Mar 2010
    Hi, I recently purchased and assembled a Sherline Mill. I'm using EMC2 and have run through all the basic setup procedures from the manual.
    I ran the test Gcode (the one that says EMC2 AXIS) and found that both the Y and Z axis are inverted. When the Z axis should go up, it goes down, and when the Y axis should go back it goes forward. I've searched this forum and a few others already but it seems like I've done some uniquely dumb thing and have found no answers.
    I can provide more information if necessary. Thanks
    Sep 2003
    OK
    Two solutions.
    1. If the motors are 4 wire bipolar, switch the A and B pair of the axis that are running in reverse.
    2. I am not familiar with that control software, but I am sure there is a setting in the motor setup for "direction" if you have it "high" or "1" then make it "low" or "0" for the axis with the problem. or if it is low or 0 then make it high or 1.
    HTH,
    Jeff
    Sep 2003
    OK
    I found the manual on emc2, look here http://www.linuxcnc.org/docs/EMC2_Getting_Started.pdf
    find the section called parallel port setup, there is a box for each axis that says invert, click on this box on the axis you are having problems with.
    That should do the trick.
    Jeff
    Nov 2006
    Open your *.ini file with a text editor. In the "AXES" section, look for the line, SCALE= . Change the sign of the number for each of the axes for which you wish to change direction. The x axis is usually axis 0, the y is axis 1, and the z is axis 2. Save the file and restart EMC2.
    In my system, for example, axis 1 and axis 2 include the line
    SCALE= -1600
    Regards
    HR
  1. HELP!!! Sherline/Ubuntu 6.06/EMC2 - Configuration
    By Telle in forum Benchtop Machines
    Last Post: 06-23-2012, 01:58 AM
  2. Sherline EMC2
    By Spunk in forum LinuxCNC (formerly EMC2)
    Last Post: 01-18-2009, 09:52 AM
  3. problem with Semeins 840- inverted G2 - G3
    By jkblack in forum Controller & Computer Solutions
    Last Post: 11-22-2008, 02:33 AM
  4. EMC2 for Sherline?
    By pepperwood in forum Benchtop Machines
    Last Post: 03-05-2008, 04:10 PM
  5. Sherline EMC2
    By JonS in forum LinuxCNC (formerly EMC2)
    Last Post: 10-25-2007, 09:34 AM
