Originally Posted by
veteq
Bye the way,
In my opinion, preloading by oversized balls is a very good method, the balls are always under pressure and are in the territory off elastic deformation.
This last thing isn`t bad, since they dont damage from it, if there is a extra force on it by accelerate or milling and it stays in the zone off elastic deformation (Law off Hooke) the ballscrew stays at same quality and dont damage. For pitch offset this is the same.
The material off the balls are a lot stiffer then the spring used in a double nut, so the stifness is at least in 1 direction greater by the first 2 configuration than by double nut.
Dont forget that a preloaded c3 screw needs a very precise base and linear motion system to operate at high quality for a longer time. If the linear motion system isn`t that precise (a dovetail Chinese mill) the expensive ultra precise screw will wear out very soon and becomes a c7 or worse.
For the Dovetail mills the Chinese ballscrews are a good match in my opinion, for the money it doesn`t get better!!!!!!!!!!!
