Way Protection
Results 1 to 8 of 8
Thread: Way Protection
    Mar 2003
    U.S.A.
    Default Way Protection
    Does anyone know of a cheap source of "way covers" for the Taig?
    I need some "accordian" style covers as the stock ones keep bunching up one me and give less than perfect protection.
    Registered cncadmin's Avatar
    Mar 2003
    Try McMaster Carr, they have them.
    Thank You,
    Paul G
    Check out-
    [URL="http://www.signs101.com"]www.signs101.com[/URL]
    Mar 2003
    Did they have what you were looking for?
    Thank You,
    Paul G
    Check out-
    Mar 2003
    U.S.A.
    Default Not really
    Too expensive. Looking for something more like what littlemachineshop.com sells. I may end up just getting 2 or 3 of their pieces of way cover material.
    Mar 2003
    I like that shop, I forgot they sell replacement parts.
    Thank You,
    Paul G
    Check out-
    Andrew
    Guest
    [Here's the best source I've found for that sort of thing. http://www.gortite.com/bellows.htm Not cheap, but it's the real deal. How much extra would you be willing to pay for bellows-style waycovers for the Taig? Is it just the Y-axis screw you thinkj needs protection, or do you want to cover the Z axis as well?]
    Andrew Werby
    www.computersculpture.com
  7. #7
    Mar 2003
    U.S.A.
    Default Cost way too high...
    I want the Y and Z. I had come across these way covers, but not sure they are going to be worth it. Will look closer at these though, thanks.
  8. #8
    Andrew
    Guest
    I hear you on the expense factor. I've thought about making them myself, using 2-part silicone rubber and gauze cloth. I use this stuff for making molds, and it seems like it wouldn't be too hard to come up with a positive bellows form to cast it onto- either an old camera bellows (if you can find one the right size) or just cutting the shape out of a piece of wood. If it was shaped that way, I'd think it would act that way, and silicone rubber is fairly impervious as well as flexible.
Way Protection
Way Protection
