need some help
Results 1 to 20 of 20
Thread: need some help
    Dec 2017
    Default need some help
    To make a long story short I replaced the motor on my Paxton Patterson CNC training mill. I took several photos as I went along to help with the reassembly and the photos were deleted from the camera. I figured out where every wire plugs into the speed controller but two; the back and white wires that feed to the back of the mill and connect to a relay. Anyone have an idea where they connect.
    Model: HP MIll
    Serial # 00578.
    Attached Thumbnails Attached Thumbnails need some help-kimg0434-jpg   need some help-kimg0435-jpg   need some help-kimg0436-jpg   need some help-kimg0437-jpg
    Member jalessi's Avatar
    Feb 2007
    Default Re: need some help
    Bison 330,
    Look around for the male spade connectors that are not attracted to anything.
    It would help if you posted images of other components that are in the general proximity.
    Welcome to the Zone,
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Dec 2017
    There are two on the speed controller (F+ F-) but I don't want to hook up the incorrect one. The black wire has 120V and I don't want to destroy the board
    Feb 2007
    Something must be wrong with my eyes, I don't see the images of the board you are referring to.
    Gold Member LeeWay's Avatar
    Jun 2004
    If they go to a speed control board, then most of those that I have seen are clearly labeled.
    Take a snap shot of the circuit board and we will give it a look.
    Lee
    Dec 2017
    I hope these images help
    Attached Thumbnails Attached Thumbnails need some help-kimg0438-jpg   need some help-kimg0439-jpg   need some help-kimg0440-jpg   need some help-kimg0441-jpg
    need some help-kimg0378-jpg   need some help-kimg0385-jpg   need some help-kimg0387-jpg
  7. #7
    Jun 2004
    The only spade terminal that I saw was on the back of the toggle switch. I don't think one wire goes there.
    Do you notice any other spade terminals anywhere?
    Lee
  8. #8
    Dec 2017
    There are two spade terminals on the speed controller. F+ and F-.
    Attached Thumbnails Attached Thumbnails need some help-kimg0376-jpg
  9. #9
    Jun 2004
    This looks like the sheet for your drive.
    http://www.galco.com/techdoc/kb/kbic-120_dat.pdf
    I am not sure, but I doubt you would be using the Field coils. F+ or F-.
    How many wires does your motor have? Does it have two brushes or none?
    Lee
  10. #10
    Feb 2007
    Where do the unconnected wires currently lead or attach to?
  11. #11
    Dec 2017
  12. #12
    Jun 2004
    What does that relay control?
    Can you read the points on the relay that it is connected to?
    Trying to determine if these are voltage side or control side of the relay.
    Lee
  13. #13
    Dec 2017
    LeeWay,
    I have no idea what the relays control.
    Attached Thumbnails Attached Thumbnails need some help-kkimg0441-jpg
  14. #14
    Jun 2004
    Do you have a multimeter?
    Lee
  15. #15
    Dec 2017
    Yes, I have a meter
  16. #16
    Jun 2004
    Check the black and white wire to see if it is getting 120 VAC across them when power is turned on.
    Lee
  17. #17
    Dec 2017
    Yes I am reading 120 from the black wire
  18. #18
    Jun 2004
    Then that wire should be power something with AC voltage. Something that is using a relay to switch on and off. Do you have a coolant pump, dust collector etc?
    Lee
  19. #19
    Dec 2017
    No pump of dust collector.....Thank you for all of your help
  20. #20
    Jan 2006
    Hate to zombify the thread, but here is the info I have on the motor speed controller you are trying to connect. The schematic I created from my current mill, and wire colors seem to vary greatly between these machines. I hope the attached pictures and pdf are clear enough to help you.
    Attached Thumbnails Attached Thumbnails need some help-img_20181003_192639529-jpg   need some help-img_20181003_192114735-jpg   need some help-img_20181003_192034574-jpg   need some help-img_20181003_191908329-jpg
    Attached Files Attached Files
need some help
need some help
