Best guess is that the ES switch is broken or came apart internally. Turn off main power, then open up the panel and see if the switch is intact. The switch contacts should be open when the button is pushed.
If the switch is OK, then the next best guess is the control power relay (if one exists in your machine) has welded contacts and needs to be replaced.
