I have some general questions I was hoping you folk might be able to help me with or point me in the direction of a better question/answer
Tormach apparently use steppers, are there similar steppers available for a budget price? Apparently they use 3 phase?
Are there best 'bang for buck' steppers?
Are there steppers to avoid?
Are the servos on aliexpress from reputable stores like BST automation ok?
On that note, I've seen 0.75kw servos for a fairly low price on BST automation, I was thinking I could buy these for my RF-45 conversion even though they are oversized, and then reuse them if I get a larger machine frame? (e.g. a skyfire). Here is a link - https://tinyurl.com/y7l3flhj .
Also, if I buy 0.75kw steppers but only use them to move the table around at lower IPM rates, can I keep the power draw down? I don't have high power circuits at my house. If I drew 3x0.75kw all at once I'd probably blow a fuse.
