Hi guys, total newbie here who can't figure out how to remove the table end caps. I see that there are two cap screws easy to remove but there are these sunk in screws which I've tried unscrewing with Allen key wrenches. I've seen people online doing the conversion using tools with T-handles not sure if they were hex or torx
Thanks guys
I figured it out, got it removed. Needed a screw extractor set. Got them out pretty easy. Thanks again
just found this video ,
watch at about 1 minute in
John
Addman16,
Do you have a 'tinkerer' friend you might partner with on your project? Removing the 'end caps' would be a fairly obvious endeavor as would identifying the type of fastener and what tool would be required to remove it. Much more difficult challenges lay ahead and a 'gearhead' buddy would be a real plus.
Stuart
Edit. Whoops..guess you were confused over the roll pins..not the SHCS...sorry.
"THE GRIZZ" photo album - https://goo.gl/photos/yLLp61jooprtYzFK7
Youtube - https://www.youtube.com/channel/UCT2lq9obzEnlEu-M56ZzT_A
