Most likely the foot pedal is a potentiometer. Yes you could use a switch to the power supply to turn it off and on.
My maxnc burnt up the motor so I ordered a consew 3/4 hp motor which seems to be popular for the taig guys. My old motors were both ac that just wire wired to an on/off switch and plugged in. I understand this one is DC and has a foot pedal. How does everyone eliminate the foot pedal and still adjust the speed? Would like a simple on/off switch (not software controlled) and a pot to adjust speed if i want to try with something other than aluminum.
Any help is appreciated
- G540 to Consew Type Servo Sewing Machine Motor
- Need Help!- VFD to motor wiring uk
- Motor wiring
- Need Help!- OLD AC motor wiring
- Need Help!- AC motor wiring
MaxNC15 - currently under construction
Torchmate 2x2 with Flashcut CNC Controls
A lazy man does it twice.
