Hi. I have disassembled the table to my RF-20 to clean everything before adjusting the feed nuts and gibbs.
I'd like to remove as much slop as possible from the thrust washer assembly.
Is there a better replacement bearing available or some sort of mod?
Or should I just clean and lube them, and shim for less backlash?
Any advice on all this would be most appreciated!
Thank you,
Bryan
