Denford Triac - Power Drawbar Ideas
Results 1 to 5 of 5
Thread: Denford Triac - Power Drawbar Ideas
    Nov 2004
    UK
    Default Denford Triac - Power Drawbar Ideas
    Hi Everyone
    I've got an early Denford Triac CNC mill and I'm lusting after a power drawbar for it - but there are some challenges! Later machines were re-designed and had a different head, spindle motor and BT30 spindle. Mine is R8 (I will use TTS tooling)
    The key challenges I've got are -
    The drawbar is extremely close to the spindle motor, so whatever I do cannot be mounted directly above. I am thinking of using some lever/cam arrangement as per Hoss's PBD 3 design.
    I am not a fan of compressed air - I've been looking at 6000N (1348lbs) linear actuators. If I aim for 2000-2500lbs with Belleville washers at the drawbar, then a 2:1 ratio lever should be about right.
    What sort of travel is typically required to remove a tts holder? The actuators I've seen quoted are 5mm/s under full load (20mm/s unloaded) - I am guessing I should be able to release a tool in under 5s with this sort of setup.
    Finally, and possibly my biggest challenge at the moment is how to make a floating design. The drawing below shows the head of my machine. There are two bearings, with a lock nut to preload them, immediately above this is a parallel section of shaft, with a keyway in it and the drive pulley for the spindle, there is then a short stub to the top of the spindle. As I understand to minimise load on the spindle bearings, I need to make a collar to attach to the spindle, which the PBD can pull against. Anybody have any bright ideas? I am struggling to see a way of making a positive fixing and getting past the pulley and keyway setup.
    Denford Triac - Power Drawbar Ideas-triac-head-jpg
    Any thoughts/advice greatly appreciated.
    Dave
    Registered MikeC8's Avatar
    Dec 2013
    Default Re: Denford Triac - Power Drawbar Ideas
    Maybe I am looking at it wrong, but I do not even see room for a stack of bellville washers with that setup.
    Work: Hurco VMX42/VMX50 - Shopsabre 4896 - HSMworks with Solidworks
    Home: RF45 with Ajax CNC Controller - Fusion 360
    Nov 2004
    UK
    Quote Originally Posted by MikeC8 View Post
    It's very tight!
    The drawing isn't quite representative as the motor is rotated to miss the drawbar bolt, so there is a bit more clearance than shown and you can drop a bar through the top cover to knock the drawbar bolt out. Incidentally, the spindle is so short that the drawbar is just a normal bolt!
    Will try and get a picture on my machine tonight.
    Nov 2004
    UK
    Some photos of the space available -
    Denford Triac - Power Drawbar Ideas-wp_20170906_18_26_51_pro-jpg
    Denford Triac - Power Drawbar Ideas-wp_20170906_18_26_56_pro-jpg
    Denford Triac - Power Drawbar Ideas-wp_20170906_18_27_09_pro-jpg
    Member Fastest1's Avatar
    Nov 2009
    Maybe use an automotive hydraulic throw out bearing assembly?
    A lazy man does it twice.
