Need Help! HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 52
Thread: HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION
  1. #21
    Member KH0UJ's Avatar
    Jul 2016
    Philippines
    Default Re: HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION
    OK just download CPU-Z sir >>> DOWNLOADING CPU-Z_1.80-EN.EXE | CPUID
    I need something like this
    if you run CPU-Z you can find your motherboard model on the mainboard tab
    Attached Thumbnails Attached Thumbnails HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION-use-cpu-z-identify-mothe-jpg
  2. #22
    Aug 2017
    k.will post in a few
  3. #23
    Aug 2017
    Manufactuer: [Dell,Inc.]
    Model: [0C27VV] [A01]
  4. #24
    Aug 2017
    Having issues with uploading pics on here. sorry. is that what you needed?
  5. #25
    Jul 2016
    Philippines
    For that, as soon as the computer starts up, press F12 when the DELL logo is displayed to enter the Boot Device Menu. With the down arrow key, select the line System Setup and press Enter. You can now change the the BIOS settings.
    Link >>>
    https://espace.cern.ch/winservices-h...ptiplex780.htm
  6. #26
    Aug 2017
    what do I need to change them to? serial port #1 is set to auto.
  7. #27
    Aug 2017
    k, I changed the raid setting like you said and rebooted my computer.
  8. #28
    Aug 2017
    it crashed the system when I switched to the RAID Autodetect / AHCI
    Attached Thumbnails Attached Thumbnails HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION-system-crash-jpg
  9. #29
    Jul 2016
    Philippines
    No sir, the steps is only for you to enter the BIOS, sorry to put the link that`s meant for the AHCI setting, you need to go to advanced settings to set the LPT1 port to epp mode
    something like this
    Attached Thumbnails Attached Thumbnails HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION-g540bios-jpg
  10. #30
    Aug 2017
    I don't see an advanced setting for the LPT1 port?
    Attached Thumbnails Attached Thumbnails HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION-lpt1-pic5-jpg   HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION-lpt1-pic4-jpg   HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION-lpt1-pic3-jpg   HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION-lpt1-pic2-jpg
    HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION-lpt1-pic1-jpg
  11. #31
    Aug 2017
    ohh in the startup f12 menu. k let me check
  12. #32
    Aug 2017
    k, got it. applied EPP mode
    Attached Thumbnails Attached Thumbnails HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION-epp-mode-jpg
  13. #33
    Aug 2017
    Quote Originally Posted by ENEEL View Post
    Aplplied the epp settings rebooted the computer use the taig profile and still got nothing from the motors when I jogged them.
  14. #34
    Jul 2016
    Philippines
    I think you`re all set sir, the only one remaining culprit you had now is the profile or the XML file settings, I think I need you to try my copy of that (......) but every time I attempt to post a link on it my whole post will be deleted my our boss here, do you have a facebook account ? or any means to transfer the file to you?
  15. #35
    Oct 2010
    Hi there
    Can u post a photo of your input signals screen in Mach?
    Cheers scott
  16. #36
    Member john-100's Avatar
    Mar 2007
    uk
    I would of thought the xml file from gecko drive will be a good start
    G540 XML File - Step Drives - Application Notes - Support | GeckoDrive
    john
  17. #37
    Member CS900's Avatar
    Aug 2006
    also make sure that the cable you got is a straight thru cable. Pin 1 on one side should go to pin 1 on the other and the same for all other pins. I had this problem my first attempt hooking up a G540. Motors would lock, but no movement.
    on that topic, are your motors locking up?
  18. #38
    Sep 2010
    Dominican Republic
    I've slowly put together my conversion to cnc on my little lathe and have got everything on and ready but i am at a standstill with my stepper motors not working. i am using mach 3 and have configured my axis,e-stop,etc. i am using plug and play stuff, a gecko g540 driver, nema23 stepper motors, have windows 7, parallel is wired straight from computer into my driver then my x,z, cables from my motors into the driver. the green power light is on without any faults.and when i turn everything on they make a slight hum noise. when i try to jog from mach3 they do nothing. it shows on the mach app that they're moving but the machine does nothing. does anyone have any idea what i'm missing here? thanks!
    I think you should get a breakout board, your computer might be putting out 3.3volts. You can find one on ebay with relay output for your spindle and coolant pump.
    Sent from my Le X522 using Tapatalk
  19. #39
    I have a similar problem with my vinyl cutter. I don't have a Driver serial port, it won't install to my computer
    Sent from my SM-G920T using Tapatalk
  20. #40
    Sep 2010
    Dominican Republic
    Quote Originally Posted by MatthewsFab View Post
    Why would you want a driver serial port? I think the parallel port cards work just fine, usb even better.
