Gecko G540 is meant as a direct parallel interface. It's compatible with 3.3V outputs.
You need to reinstall mach3 and void the parallel port option, then go through the proper plug in
Sent from my Le X522 using Tapatalk
yes they lock, let out a hum. but wont budge while jogging
thorough video update on the issues I'm having.
What stepper motors do you have? It looks like they're plugged straight into the G540, normally you need to wire up the DB9 connectors on the G540 yourself to have the proper pinout and have the current set resistors in them.
Good luck with that, probably won't work unless its specially designed to be compatible with Mach3...
If it's a UC100, it should work with Mach.
CNCdrive - motion controls
Mach3 - Newfangled Solutions
Software Requirements
Mach3 Minimum Recommended Requirements:
Requirements if using the parallel port for machine control:
•Desktop PC (Laptops are not supported) with at least one parallel port
•32-bit version of Windows 2000, Windows XP, Windows Vista, or Windows 7 (64-bit versions will not work)
•1Ghz CPU
•512MB RAM
•Non-integrated Video Card with 32MB RAM(Large G-code files, especially 3D files will require a video card with 512MB RAM or higher)
