Need Help! HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION - Page 4
Page 4 of 5 FirstFirst 12345 LastLast
Results 37 to 48 of 52
Thread: HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION
  1. #37
    Registered CS900's Avatar
    Aug 2006
    Default Re: HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION
    also make sure that the cable you got is a straight thru cable. Pin 1 on one side should go to pin 1 on the other and the same for all other pins. I had this problem my first attempt hooking up a G540. Motors would lock, but no movement.
    on that topic, are your motors locking up?
  2. #38
    Sep 2010
    Dominican Republic
    Quote Originally Posted by ENEEL View Post
    I've slowly put together my conversion to cnc on my little lathe and have got everything on and ready but i am at a standstill with my stepper motors not working. i am using mach 3 and have configured my axis,e-stop,etc. i am using plug and play stuff, a gecko g540 driver, nema23 stepper motors, have windows 7, parallel is wired straight from computer into my driver then my x,z, cables from my motors into the driver. the green power light is on without any faults.and when i turn everything on they make a slight hum noise. when i try to jog from mach3 they do nothing. it shows on the mach app that they're moving but the machine does nothing. does anyone have any idea what i'm missing here? thanks!
    I think you should get a breakout board, your computer might be putting out 3.3volts. You can find one on ebay with relay output for your spindle and coolant pump.
    Sent from my Le X522 using Tapatalk
  3. #39
    Registered MatthewsFab's Avatar
    Oct 2014
    I have a similar problem with my vinyl cutter. I don't have a Driver serial port, it won't install to my computer
    Sent from my SM-G920T using Tapatalk
  4. #40
    Sep 2010
    Dominican Republic
    Quote Originally Posted by MatthewsFab View Post
    Why would you want a driver serial port? I think the parallel port cards work just fine, usb even better.
  5. #41
    Jun 2011
    Gecko G540 is meant as a direct parallel interface. It's compatible with 3.3V outputs.
  6. #42
    Oct 2014
    Quote Originally Posted by ArturoMoises1 View Post
    I have the USB plug, but when I plug it into my computer, it has an error in the Device manager. It supposed to show a serial port driver in the Device manager under USB's but it won't install the driver properly
  7. #43
    Registered KH0UJ's Avatar
    Jul 2016
    Philippines
    maybe because you need to install a USB plug-in on it on mach 3 (supplied by your BOB manufacturer) to make it work I guess?
  8. #44
    Jun 2011
    I don't think your problem is related to the problem of the OP. You should probably start a new thread and detail your issue.
  9. #45
    Sep 2010
    Dominican Republic
    You need to reinstall mach3 and void the parallel port option, then go through the proper plug in
  10. #46
    Registered ENEEL's Avatar
    Aug 2017
    yes they lock, let out a hum. but wont budge while jogging
  11. #47
    Aug 2017
    thorough video update on the issues I'm having.
  12. #48
    Jun 2011
    What stepper motors do you have? It looks like they're plugged straight into the G540, normally you need to wire up the DB9 connectors on the G540 yourself to have the proper pinout and have the current set resistors in them.
