Need Help! HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION - Page 3
Page 3 of 5 FirstFirst 12345 LastLast
Results 25 to 36 of 52
Thread: HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION
  1. #25
    Registered KH0UJ's Avatar
    Jul 2016
    Philippines
    Default Re: HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION
    For that, as soon as the computer starts up, press F12 when the DELL logo is displayed to enter the Boot Device Menu. With the down arrow key, select the line System Setup and press Enter. You can now change the the BIOS settings.
    Link >>>
    https://espace.cern.ch/winservices-h...ptiplex780.htm
  2. #26
    Registered ENEEL's Avatar
    Aug 2017
    what do I need to change them to? serial port #1 is set to auto.
  3. #27
    Aug 2017
    k, I changed the raid setting like you said and rebooted my computer.
  4. #28
    Aug 2017
    HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION-system-crash-jpgit crashed the system when I switched to the RAID Autodetect / AHCI
    Attached Thumbnails Attached Thumbnails HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION-system-crash-jpg
  5. #29
    Jul 2016
    Philippines
    No sir, the steps is only for you to enter the BIOS, sorry to put the link that`s meant for the AHCI setting, you need to go to advanced settings to set the LPT1 port to epp mode
    something like this
    HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION-g540bios-jpg
    Attached Thumbnails Attached Thumbnails HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION-g540bios-jpg
  6. #30
    Aug 2017
    I don't see an advanced setting for the LPT1 port?
    Attached Thumbnails Attached Thumbnails HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION-lpt1-pic5-jpg   HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION-lpt1-pic4-jpg   HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION-lpt1-pic3-jpg   HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION-lpt1-pic2-jpg
    HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION-lpt1-pic1-jpg
  7. #31
    Aug 2017
    ohh in the startup f12 menu. k let me check
  8. #32
    Aug 2017
    HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION-epp-mode-jpg
    k, got it. applied EPP mode
    Attached Thumbnails Attached Thumbnails HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION-epp-mode-jpg
  9. #33
    Aug 2017
    Quote Originally Posted by ENEEL View Post
    Aplplied the epp settings rebooted the computer use the taig profile and still got nothing from the motors when I jogged them.
  10. #34
    Jul 2016
    Philippines
    I think you`re all set sir, the only one remaining culprit you had now is the profile or the XML file settings, I think I need you to try my copy of that (......) but every time I attempt to post a link on it my whole post will be deleted my our boss here, do you have a facebook account ? or any means to transfer the file to you?
  11. #35
    Oct 2010
    Hi there
    Can u post a photo of your input signals screen in Mach?
    Cheers scott
  12. #36
    Registered john-100's Avatar
    Mar 2007
    uk
    I would of thought the xml file from gecko drive will be a good start
    G540 XML File - Step Drives - Application Notes - Support | GeckoDrive
    john
