Need Help! HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION - Page 2
Page 2 of 5 FirstFirst 12345 LastLast
Results 13 to 24 of 49
Thread: HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION
  1. #13
    Registered john-100's Avatar
    Mar 2007
    uk
    Default Re: HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION
    see page 62 of the mach 3 manual to setup the motor outputs
    HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION-page-62-motor-outputs-jpg
    use the pin numbers printed on the G540
    if an axis runs in the wrong direction change the direction pin setting to active low
    John
  2. #14
    Registered KH0UJ's Avatar
    Jul 2016
    Philippines
    This is what you lack on your settings.
    You need to set the red square with the values suggested by gecko, on the chinese machines it`s X=2,3 Y=5,6 Z=7,8, it all depends on what model, some are a bit odd some are standardized, after that if all your axis move go back here to re calibration steps, if you know what to do on axis calibration I think you proceed on that
    Attached Thumbnails Attached Thumbnails HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION-page-62-motor-outputs-jpg
  3. #15
    Registered ENEEL's Avatar
    Aug 2017
    I show that I have already defined them in the video
  4. #16
    Jul 2016
    Philippines
    Wait can you show us the BIOS on your PC? something like this>>>>>>>
    First you need to boot up in the BIOS of you PC and take a look on this settings on LPT1 port configuration, or just post here your motherboard model let me look it for you and post here what you need to set on the advanced settings on the parallel port
  5. #17
    Aug 2017
    where can i find my motherboard info? i will send you the info.i am new at this so nothing makes much sense yet. thank you for helping so much!
  6. #18
    Jul 2016
    Philippines
    The most accurate way to identify your motherboard model is to open your PC case, take a peek on the numbers or just post a picture on it and post it here, we can locate and identify it for you or just power up your PC then press delete or f2 (really depends on motherboard model) to enter BIOS environment.
    or just type DXDIAG on the run on start menu to find your motherboard model, or download CPU-Z and run it to find your motherboard model that`s if your on windows environment.
  7. #19
    Aug 2017
    Quote Originally Posted by KH0UJ View Post
    the most accurate way to identify your motherboard model is to open your PC case, take a peek on the numbers or just post a picture on it and post it here, we can locate and identify it for you or just power up your PC then press delete or f2 (really depends on motherboard model) to enter BIOS environment.
    I will do this right now. Give me a few minutes and I will post it
  8. #20
    Aug 2017
    BIOS Version =A15
  9. #21
    Jul 2016
    Philippines
    OK just download CPU-Z sir >>> DOWNLOADING CPU-Z_1.80-EN.EXE | CPUID
    I need something like this
    HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION-use-cpu-z-identify-mothe-jpg
    if you run CPU-Z you can find your motherboard model on the mainboard tab
    Attached Thumbnails Attached Thumbnails HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION-use-cpu-z-identify-mothe-jpg
  10. #22
    Aug 2017
    k.will post in a few
  11. #23
    Aug 2017
    Manufactuer: [Dell,Inc.]
    Model: [0C27VV] [A01]
  12. #24
    Aug 2017
    Having issues with uploading pics on here. sorry. is that what you needed?
