Originally Posted by
DJEkim33
Interfacing the C35 to the 7i76e will require firmware I believe and maybe a bigger headache than you think for someone learning linuxcnc.
Great advice. I am going to ditch that idea.
DJEkim33
So no core isolation and if the OP is dead set on using a 7i76e than he will need to change the kernel which is one thing he was trying to avoid. Changing the kernel is easy enough though if he still wants to go that route.
Well, I suppose I need to get smart on changing the kernel...here I thought all computers ran in 'real time'.
This is good info.
PCW_MESA
In addition, Preempt-RT which is needed for Mesa Ethernet cards generally runs better on faster CPUs so a J1800/J1900 or the newer
N3355/J3455s are _much_ better than a (painfully slow) D525
That definitely opens up more options for motherboards/processors...and I am starting to think about maybe just building one of these mini-ITX form factor computers to keep it small.
PCW_MESA
And as I said before isolcpus is a BAD idea if you are not running a parallel port system,
Sorry. Failure of reading comprehension 101 on my part. I think I'm starting to get a better sight picture for the setup I am going for, and surprisingly I think it might be less finicky than I first imagined.
PCW_MESA
If using a Mesa Ethernet interface card, I would start with the new LinuxCNC Debian Stretch test ISO:
Index of /testing-stretch-rtpreempt
Since this ISO has the uspace version of LinuxCNC and the required Preempt-RT kernel already
Thank you for the link...this is very critical information for my setup!
I am going to document all of my lessons learned in this journey so that maybe someday I can try a feeble attempt at a build thread titled "CNC Converting a G0704 with LinuxCNC for Dummies Like Me".
v/r,
JJ
