Need Help! what type of motor controller to buy
Results 1 to 3 of 3
Thread: what type of motor controller to buy
    Default what type of motor controller to buy
    I have a g0704 in converted to cnc using mach3. I have had good success, I am looking to convert the spindle to a DC DC tread mill motor. I have a couple 6000 rpm motors. any recommendations on what motor controller power supply to buy.
    Aug 2016
    Default Re: what type of motor controller to buy
    Kbmm-125. You can use it on your stock motor and on the 1100w if you decide to upgrade.
    Check out hoss' page under projects for info.
    Dec 2003
    Or if you want a little superior one that is quieter and smoother at low rpms's look for the KB PWM version over the SCR type.
