Originally Posted by
Roadstercycle
OK, this is a bit premature but since I want input before I start I thought I'd throw it out there and see what sticks. I just ordered a Grizzley G0704 to help with the conversion because it seems you need a mill to build a mill and since I just sold my RF 31 CNC conversion I put myself in a bind. The G0704 is going to so much nicer than that round column on the RF31. Anyway since I'll have it down for that I may do the belt drive too so I'll murder 2 birds with 1 machine. OK so back to the conversion. My thoughts are Hiwin 20 rails and 4 bearing blocks. I'll need to cut the tips of the dove tails to give some extra room for the rails and block. The rotating back plate needs to be machined to accept the blocks. This is where a little helpful brain storming from you guys may help. I was also thinking I may just get a 13" x 13" piece of 1.5" thick 6061 aluminum and machine and bolt my head to it and get rid of the dove tail rotating casting all together. Nail it as close as possible straight up and down and leave a little clearance in the mounting holes for bumping perfect when tramping it in. So my questions are: Do you guys think that the 1.5" aluminum plate will be strong enough to avoid flexing or should I go with a 1.5" thick steel plate? Or just machine the stock rotating plate for the bearing guides? I saw how one guy did it with looked like a G0704 but I've not seen an I.H. conversion yet. I would think someone would have done it already. So if anyone has any good ideas I'd love to hear them. Or if you know where a conversion thread is, let me know. I don't need to reinvent the wheel.
Here's a couple pics of my mill and the dovetail area. I have to sneak the rail and bearing block into that area next to the dove tail. If I take about 3/8" off the dovetail tip it should work fine.
The Mill is a I.H. Charter
3 phase 3HP Baldor motor with VFD
Quick tool changer with Tormach TSS. Would you believe I found that air cylinder on Ebay for $95. I couldn't hit the "Buy it Now" button fast enough. I priced a new one $650 plus shipping, Yikes.... I am still able to use the spindle handle for quick drilling and my tapamatic setup
It has double ball screws and it still has manual use besides full CNC
Rotary table 4th axis.
