Need Help! Prolight 3000 Turning Center
Results 1 to 17 of 17
Thread: Prolight 3000 Turning Center
    Mar 2017
    Default Prolight 3000 Turning Center
    I just bought a Prolight 3000 lathe turning center from a closing school. Came with everything, ATC, ISA card, control box and everything else. I would like to upgrade it tho because the softwaer is kinda limited and computer is old because of isa card. I looked up a little and doing a Mach3 conversion is apparently the way to go. I am very new at this, only have worked with new CNC never modified any. What would be the parts I need? I know I would need a control board but is that it? What brand is the best for this application and somewhat easy?? Thanks!
    Jul 2005
    Default Re: Prolight 3000 Turning Center
    I bought a Prolight 3000 last year. It had come from a school, and I got it intact and working, original computer and all. I have used it several times since, and I can just say - use it the way it is. The software does all the normal things, and you don't have to mess around with anything. It's not hard to use, once you are used to the interface. Mine runs under Win95, so yes it's old. However, it works just fine, so I use it as is. Since you are just learning anyway, there is no advantage to updating the controls until they fail on you. Keep in mind that that may happen, but until then - make chips!
    Incidentally - you have a lucky find - mine didn't come with the turret(ATC), nor a tailstock (factory option, never installed). I found a second one, with no driver box or computer, and it doesn't have the ATC or tailstock, either. (The second one is set up for gang-tooling, though).
    Mar 2017
    Quote Originally Posted by DSpeck View Post
    I was going to do that but what's happening is I use Fusion 360 just because I have used it forever and know it well. But it makes the machine plunge and do weird movements but in the simulation In fusion it doesn't? What cad cam program do you use?
    Jul 2005
    I usually hand-write the program. Hand-writing lathe code is a lot easier than mill code. I've used Mastercam at work, for some parts there. There are a few free lathe CAM programs around, for basic 2-axis lathe stuff. Look up Ezilathe, and GrblGru, as a couple of examples. I have several other CNC lathe projects, but they all need modernized controls, so I haven't done a lot with lathe CAM yet.
    Mar 2005
    The post processors in Fusion 360 are written in javascript and very easy to modify. My CNC lathe uses an AhHa controller that has quite a few unconventional gcodes but I was able to easily make it work.
    I'd be happy to work with you to get a working post for your controller. Here's a thread where a couple of us worked on making a post processor for the Dynamechtronics SKIP controller where the code is far from gcode: http://www.cnczone.com/forums/dyna-m...oftware-2.html
    Let me know.
    Dave
    Mar 2017
    Quote Originally Posted by dammachines View Post
    Let me know.
    Dave
    Hey Dave that would be great! I'm pretty new to this so that would be great. Right now it's a stock controller.
    Sent from my iPhone using Tapatalk Pro
  7. #7
    Mar 2005
    Quote Originally Posted by 4DCustoms View Post
    Does this look like the manual for your controller? http://www.intelitekdownloads.com/Ma...WIN_Manual.pdf
    What post are you using right now? The generic fanuc? Can you attach a copy of a program you've tried to run unsuccessfully?
  8. #8
    Mar 2005
    Oh, I think you might want to take a look here before we do anything. https://forums.autodesk.com/t5/hsm-p...ht/true#M10373
    Looks like Autodesk already has a turning post available!
    Dave
    Funny during my search I see that I've already worked with someone on a Prolight 3000 post a while ago. https://forums.autodesk.com/t5/hsm-p...ght/true#M3749
  9. #9
    Mar 2017
    Dave
    That's the thing! I use that post haha and it still doesn't work that's my problem.
  10. #10
    Mar 2005
    Ha! Well, that answers my post question.
    Do you have a sample program that you've tried to run? We'll figure it out.
  11. #11
    Mar 2017
    Yea just upload the .nc?
  12. #12
    Mar 2005
    Yeah, the .nc file and some information on what the lathe is doing wrong. Are any of the moves what you expect?
  13. #13
    Jan 2006
    Dave, I stumbled upon your posts here, lucky you!
    I just bought an old CNC Lathe, It's a "Red Cam RLA9200" that came from a school and was used very little, looks new.
    It uses AHHA. I have never run a CNC Lathe but have run CNC router/mill/plasma for years. I have no problem writing Gcode for that. I have no code for the lathe, I tried to write a simple code for the lathe thinking it's just 2 axis and m3m5 to turn on off the spin. I have had very limited results, there is something missing in the code i am trying to use. Is there any chance you could share a simple code that would run your ahha lathe? I expect that if I get the start sequence and see a few code details, I could then edit and write code that would work. I just need to get spindle rotation and a couple short moves on the 2 axis to get started.
  14. #14
    Jan 2006
    Morgan
  15. #15
    Mar 2005
    Hey Morgan,
    Yeah the Ahha control definitely has some oddities. Let's see if I can remember a few... It is radius mode only. X coordinates are negative if you use a front tool post. Most (if not all) numbers need to have a decimal point in them. G28 doesn't work well on my machine, but that might be just my machine because of something in the MCDMAP.AGC file (contains the macros for things like tool changer, spindle control, etc). I know there are more. My brain is just a little worn out at the end of the week here.. : ) Have you checked out the AHHA yahoo group? There should still be some info there on tool offsets and threading.
    I've attached the code that I believe should be the part on that Youtube video. Should give you a good start! Feel free to PM me here if you have any specific questions - so we don't take this thread off topic for too long.
    Dave
    Attached Files Attached Files
  16. #16
    Jan 2006
    Thanks a million Dave! I ran downstairs and added the decimals, It Works! Thank You!
    Morgan
  17. #17
    Mar 2017
    Hey Dave! Sorry for the late response I was away all week but there are some weird movement, I think around line 34 it plunges for no reason here is the .nc code 'PAWN.nc' | TextUploader.com
  18. #18
    alvinkane's Avatar
    Feb 2024
    Assignment help services offer comprehensive assistance to students seeking support with their academic tasks. From essays to research papers, these services provide expert guidance to enhance students' understanding and improve their grades. Whether it's resit dissertation help or assistance with any other academic assignment, these services ensure timely and quality solutions tailored to individual needs.
  19. #19
    alvinkane's Avatar
    Feb 2024
    Assignment help services provide comprehensive assistance to students in completing their academic tasks, ranging from essays to dissertations. They offer specialized support in various subjects and formats, ensuring high-quality work and timely delivery. For instance, if you require assistance with a case study, Case Study Help services can provide tailored solutions to meet your specific requirements, aiding you in achieving academic success.
  20. #20
    alvinkane's Avatar
    Feb 2024
    Looking for the best assignment help? Look no further! Our professional service offers top-notch assistance to students struggling with their assignments. With experienced experts in various fields, we guarantee high-quality solutions tailored to your specific needs. Say goodbye to stress and meet your academic goals with our best assignment help service!
    University Assignment Help London
    University Assignment Help Perth
