Spindal Motor Connections
Results 1 to 2 of 2
Thread: Spindal Motor Connections
    Mar 2017
    Default Spindal Motor Connections
    I have a 3 axis TB 6560 controller I want to connect a spindle motor to it, the outputs available are under output are GND,Pwm under relayM1 M2 I would appreciate any help.
    Jun 2005
    Default Re: Spindal Motor Connections
    bmartin7,
    That is meant to connect to a VFD and Spindle. The relays are used to control the spindle start and direction, and the PWM output is normally used to output a voltage between 0-10V which connects to the VFD as a speed input.
    Russ
