It's normal to have a spot that's a bit tighter. They are machined, but the imports aren't the most precise. Hopefully nothing is bent.
Best bet is to remove the tapered gibs and check the gibs and ways for any mars, nicks or damage. It could just be a chip or something. Check them, clean them and reinstall and adjust them properly. Cleaning and.proper adjustment may fix the issue. You can finish/polish them to make them more accurate and smoother but that's a whole new can of worms that usually isn't necessary.
