Build Thread THE GRIZZ - Page 45
Page 45 of 52 FirstFirst ... 3542434445464748 ... LastLast
Results 529 to 540 of 617
Thread: THE GRIZZ
  1. #529
    Oct 2013
    Default Re: THE GRIZZ
    Just a little note, sans pictures. We made a 'air part' from a Mach4 canned bolt hole program complete with peck cycles. Man am I excited..it really does work just like a real machine. Nick will have a video a little later but I wanted to share my excitement now.
    I've order Champagne and dancing girls for the 'grand reveal', which should happen soon..hope my wife doesn't find out!!
    Stuart
    "THE GRIZZ" photo album - https://goo.gl/photos/yLLp61jooprtYzFK7
    Youtube - https://www.youtube.com/channel/UCT2lq9obzEnlEu-M56ZzT_A
  2. #530
    Oct 2013
  3. #531
    Aug 2008
    Quote Originally Posted by atomarc View Post
    Looking good!! Bet you guys are super excited to see it run some code!! Looks sweet!! Keep it up!!
    Sent from my QTAIR7 using Tapatalk
  4. #532
    Oct 2013
    Chris,
    Thanks..yes, we're anxious to make chips. Soon I hope!
    QUESTION. I have seen this program in a video but I don't know what's it's called;
    Machine is told to home.
    Machine homes in all axis, then instead of backing off slightly, it returns the X and Y to their approximate center and drops Z to a preset height. This means the vice or part is centered under the spindle.
    What is that called, where can I see a video of it and who the heck can help me write a Mach4 Lua script that will make that happen?
    Thanks,
    Stuart
  5. #533
    Aug 2008
    Stuart
    I'm sure a basic little gcode program could accomplish that, but unless you're going to cut the exact same part over & over .. why put the spindle at center of table all the time after homing?
    Maybe I'm doing it the hard way, but after booting up the machine, I home, then set stock in vise, probe the stock to establish work offsets, and then run a program.
    Once the machine is homed, it's not necessary to do it again unless there's a crash, or problem with motion, or you turn it off & restart.
    Have I missed something about why you would want your spindle going to center of table when you home?
    If you are thinking of a handy position for inserting /changing tools during a job, you should be able to tell Mach where to go for tool changes. I use the Mach Standard Mill screenset & have a custom macro written that puts the spindle where I want it for tool change,
    then goes over to the corner of table to measure each tool before cutting. (too many mess-ups in the tool table as I was learning, so I don't even bother with a tool table any more)
    Your machine looks absolutely beautiful by the way .. stellar work & a awesome father /son project. My son & I coordinated on a CNC Router for him to make custom guitars & I totally enjoyed every minute of it.
    Gary
  6. #534
    Oct 2013
    Gary,
    Thanks for the feedback. To be honest, having never done this CNC stuff before I'm not 100% sure how it should be. When I (we) home the machine, it goes to all it's extremes, backs off a tad then sits. In our case, this means the table is full left, full forward and the spindle is full up. You're right, this only happens once..when you home it.
    This is a awkward position for the table as the vise (if used) is far left and forward and barely accessible. I (we) would like the table to come 'center' after it homes that one time. I believe in Mach3 there is a function that you can program to set the 'back off distance from the home switch. In Mach4 that must be written with a LUA script..which isn't a simple thing for a simpleton like me.
    My experience is with a manual machine where the vise is always centered on the X axis and usually the Y axis. This is home base, where you load the vise and start your work.
    So...to get net, the Grizz homes just fine in all axis, but after it hits the home switch, instead of merely backing off several thousandths, I would like it to return to 'center stage', as it were. Does this make sense? I am almost sure I've seen other machines...maybe even a G0704 do this very thing.
    Stuart
  7. #535
    Aug 2008
    Stuart
    Gotcha .. so it's an 'easier to work with from there' kind of thing .. I can understand that.
    With my machine it seems like I'm manually jogging the axis around quite a bit during a set-up anyway, so I wasn't thinking about it simply being a convenience issue.
    Once you become more comfortable with using your machine, you will likely find yourself jogging around in rapid mode a lot.
    The ability to move an axis anywhere you want it quickly with the push of a button beats the heck out of turning hand cranks!
    Wish I could help you with the LUA script. I've never used Mach4 so can't be of any help there.
    Gary
  8. #536
    Oct 2013
    Gary,
    Thank you. We'll keep at it, for sure. The one year anniversary date for the machine is coming up in a few days and I had hoped to be making chips by then. It still might happen...if the stars align.
    Stuart
  9. #537
    Dec 2015
    I usually prefer my tool change position and my part loading positions to be the same. This usually comprises the table being as close to front of the enclosure as possible (nearly as Y- as it will go), but no so far that I can't use a tool height setter on the bed to the left of the vise. For the X axis, I like to setup the vise in the middle of the table, but for tool change for part loading I like the table X+ nearly as far as it can go. This gives room between the vise and hopefully open air for part loading. For Z, I like it at maximum Z+. And as mentioned, I jog all of the time. Between the pendant and the probe I can definitely say that jogging is a huge part of just about every setup.
    I see lots of your photos, see the work you have done here, and you know way more about milling/machining than I do. That said, I own a G0704 and with very little space between a tool and the vise even at max Z+ the above settings have worked the best for me. I use anywhere between 4 inch vises to a 6 inch vise and a 6" 3-jaw chuck to give you an idea of my work environment / standard setups are used. Loading in an 80 lbs vise is also much easier when the table is close to the front edge of the enclosure and that helps.
    All of this said, I'm sure every guy has a preference and they likely vary endlessly.
  10. #538
    Oct 2013
    Quote Originally Posted by CL_MotoTech View Post
    Thanks for the comments. I can crank a manual handle but I haven't done what you have, and that's run a CNC machine, so you're much more knowledgeable than I am.
    Nick had a forum friend helping him on the programming (Mach4) and he now has the ability to run the X and Y to their centers after homing. This is what I was trying to achieve, so we're getting closer.
    Thanks,
    Stuart & Nick
  11. #539
    Oct 2013
    here are some quick videos documenting the custom homing sequence for mach4 that has been coming together over the last week. The machine is currently waiting on a replacement hydraulic seal for the draw-bar cylinder. Getting closer...
  12. #540
    Oct 2013
    Was able to run some test g code. Stuart made a cool floating sharpie holder. A touch of fusion and 'bob's our uncle'. If you notice the start date on "the grizz" build (12/9/16) ....happy one year anniversary! omg! Last week a new draw bar cylinder was made (other one was....leaking.."unapparent design flaw") . Tomorrow, planning on putting the draw-bar back together and testing.... fingers crossed.
THE GRIZZ
THE GRIZZ
