Build Thread THE GRIZZ - Page 36
Page 36 of 44 FirstFirst ... 2633343536373839 ... LastLast
Results 421 to 432 of 525
Thread: THE GRIZZ
  1. #421
    Oct 2013
    Default Re: THE GRIZZ
    more assembly... have the bulk of the interface installed, waiting for the wiring stages to receive the face plate with all the buttons. Happy with how the homemade friction pivots work, adjust. The magnet provides for a nice positive closure.
    "THE GRIZZ" photo album - https://goo.gl/photos/yLLp61jooprtYzFK7
    Youtube - https://www.youtube.com/channel/UCT2lq9obzEnlEu-M56ZzT_A
  2. #422
    Oct 2013
    Also did some work on the doors... installed stainless hardware, slides...... they really do work sweet and i think they will be fine due to being "well-ish" protected by the doors. Looking forward to going christmas morning on the doors!
  3. #423
    Oct 2013
    Installed the stainless steel edge guard with 3M tape... ...... enclosure lights as well.
  4. #424
    Oct 2013
    getting the X & Z linear rails ready to be aligned.....
    - Nick
  5. #425
    Aug 2016
    Heads up, when you install the base on that flat surface, you're going to want to cut a relief, or shim it up a little bit for coolant drainage.
    Even though you have way covers, coolant will find its way in between. I found out that I had a cesspool after a few months of removing the way covers. I ended up using .050 thick aluminum spacers to shim the base from the mouting surface, and now it drains.
  6. #426
    Oct 2013
    Quote Originally Posted by Joey5226 View Post
    Joey,
    Great tip, thanks. We'll take a look and see what we can do.
    Stuart
  7. #427
    Oct 2013
    more assembly..... still having a blast! I have a kick ass mentor / father! Thanks paw.
    - Nick
    (a super awesome video ferrrr you! Thanks for the subscriptions & feedback! )
  8. #428
    Oct 2013
    because pictures are nice...... i feel like the green caps are in backwards but looking at them and trying them the other way they just wont go.... flipped over (smooth side up) the draft or taper of the plug goes the wrong way... i.e not go in the hole! lol. perhaps further investigation will reveal the answer! my luck they are in backwards!
  9. #429
    Registered Chris D's Avatar
    Apr 2005
    green caps are backwards. When installed, the surface should be smooth.
    Chris D
  10. #430
    Oct 2013
    Quote Originally Posted by Chris D View Post
    Chris D
    Chris,
    We had fun snapping them in then did some research and, just as you point out...they're in wrong. I popped one out and it wasn't too difficult so we'll give it a college try on the others and see what happens.
    Thanks,
    Stuart
  11. #431
    Oct 2013
    Successfully got the green caps turned around! since they where in backwards it was semi easy to remove them!! = ) ......... some last minute machining on the base, added some groves for coolant / oil to escape. (thanks Joey)
  12. #432
    Aug 2008
    Looks good!! Keep it up!! Time for some chip making soon!
    Sent from my QTAIR7 using Tapatalk
THE GRIZZ
THE GRIZZ
