Originally Posted by
109jb
Looking at the torque curves on the Automation Tech site, the torque in parallel at 300 rpm (about 60 IPM) is about 480 oz-in, compared to 290 oz-in in series. So you are only getting about 60% of the torque at your rapid speed that you could be. The torque in paralle would not drop to 290 until about 500 rpm, which could give you 100 IPM rapids. Even at that you are slow. My G0704 rapids 180IPM all day long with a more basic driver using the 570 oz-in motor with no counterweight or helper springs.. How tight are your gibs?
Also, the motor temp that you cited (110-120F) is nothing. Stepper motors are commonly rated for case temps up to 100 deg C (212 F). I see a lot of worry about stepper temp that I believe is unfounded.
