Optimum BF20 (G0704) few ideas
Results 1 to 8 of 8
Thread: Optimum BF20 (G0704) few ideas
    Jun 2014
    Default Optimum BF20 (G0704) few ideas
    I will show here few ideas I did on my machine. Maybe, it is already somewhere - but maybe not yet.
    first of all - Z axis
    I used ballscrew 20 / 05
    the body for the nut is from 2 parts - look at the one piece imbus M12 screw on the bottom. It is in hole -diameter 12mm, with plastic washer to hold it in place for assembly
    Optimum BF20 (G0704)  few ideas-dscn2934-jpg
    imbus set screw ? (is that right ?)
    Optimum BF20 (G0704)  few ideas-dilna-20140508-095a-jpg
    the idea is to tighten this screw to M12 in centre through the M12 hole
    Optimum BF20 (G0704)  few ideas-dilna-20140511-097b-jpg
    by the way, if the three nuts are M12 - their head fits exactly to the round slot
    Attached Thumbnails Attached Thumbnails Optimum BF20 (G0704)  few ideas-dscn2934-jpg   Optimum BF20 (G0704)  few ideas-dilna-20140508-095a-jpg   Optimum BF20 (G0704)  few ideas-dilna-20140511-097b-jpg
    Jun 2014
    Default Re: Optimum BF20 (G0704) few ideas
    BF20 uses MT2 for tool fixing (I do not plan toolchanger)
    the tool is fixed in place by M10 x 1,5mm thread - part (114)
    to release tool from MT2 - part (114) leans against part (112) - one turn moves about 1,5mm and it is sometimes difficult to release MT2 - often you must hit the screw on top.
    Optimum BF20 (G0704)  few ideas-bf20orig-jpg
    I did replace part (114) and (112) as you can see in the picture (botom is the original (114))
    When I tighten new part 114a by one turn, it pulls MT2 tool 1,5mm up and at the same time part 114a moves in nut M20x1,0mm - 1,0mm down. That is - I tighten MT2 tool by 0,5mm on one turn - now, just by hand I have enough power to tighten tool and mainly to release the tool - sometimes I use key to release - but never need to hit anything.
    (M20 x 1,0 is the origin thread on part 112 - no need any other changes to machine)
    Optimum BF20 (G0704)  few ideas-dscn3486-jpg
    Optimum BF20 (G0704)  few ideas-pouzdro-jpg
    Optimum BF20 (G0704)  few ideas-dscn3487-jpg
    Jun 2014
    My belt conversion
    I decided to change to 3f motor + VFD -
    get rid of noisy gear
    get more reliable motor
    get easier control by VFD
    my choice was power motor (650W / 2,3Nm in size of 550W motor)
    1. elektromotor 1LA9070-2LA12
    SIMOTICS GP LOW-VOLTG. SQUIRREL-CAGE MOTOR IP55,
    WITH INCREASED RATING 2-POLE,THERM.CL.155(F)*
    SIZE 71M ALUMINUM ENCL.
    3 AC 50HZ 230VD/400VY * 0,65 KW 2750 ot.
    3 AC 60HZ 460VY * 0,75 KW
    220-240/380-420 (50HZ)
    belt - HTD5M x 15mm x 450 mm
    pulley motor - 64 / spindle - 36 center distance - 97,5 mm max speed 9778 at 100Hz
    pulley motor - 30 / spindle - 68 center distance - 97,9 mm max speed 2426 at 100Hz
    in practice - over 6000 the big ball-bearing on top gets hot
    and top speed is about 8000 - I have 750W VFD and it has no more power
    sometimes I run motor around 15Hz (speed 350) and motor does not need external cooling
    for me - I am satisfied with my belt conversion
    chart - Nm / speed
    Optimum BF20 (G0704)  few ideas-moment-jpg
    Pulleys and shield are made by 3D print / ABS - it is in use for about 30 hours of work without any wear (it is hobby machine :-) )
    Optimum BF20 (G0704)  few ideas-dscn4217-jpg
    Optimum BF20 (G0704)  few ideas-dscn4319-jpg
    Dec 2016
    Sweden
    Nice beltconversion.
    I am planning for something similar. How have you connected the pulleys to the spindle?
    Jun 2014
    one part glued to spindle (take down the part with magnets)
    Optimum BF20 (G0704)  few ideas-vr00-jpg
    on it there is collet with angle same as on sheave
    Optimum BF20 (G0704)  few ideas-vr01-jpg
    and fixed with nut M40 x 1,5 (holes in it to tigten)
    Optimum BF20 (G0704)  few ideas-vr02-jpg
    OK ?
    Dec 2016
    Sweden
    Thanks for the quick answer.
    I have to take it a part som mayby I understand it better
  7. #7
    Jun 2014
    on top of part "206" I had ring with 4 magnets for measuring spindle speed - I did remove it (maybe you have another detail for measuring spindle speed)
    (I measure speed on top of the cover - little blue dot on picture not ideal, must redo it)
    Optimum BF20 (G0704)  few ideas-vr03-jpg
    and the left side of this - I put inside part 206
    (on the right side there is thread M40 x 1,5 for nut)
    (the dimension 19,50 is for the collet
    take it as princip - if you need details ask for them
  8. #8
    Jun 2014
    my new probe - after problems with clasic probe, where using collet to hold the probe gave me error up to 0,05mm + error of the probe
    I decided to make the probe fixed to the mill body. Now repeatable accuracy mesuring position is < 0,015 mm. Mach3 macro calculates the exact position of "zero" from measured position by probe. The probe can mesure only X - Y direction, not Z
    Second picture is cover, when the probe is not used.
    Optimum BF20 (G0704)  few ideas-img_0164-jpgOptimum BF20 (G0704)  few ideas-img_0154-jpg
    Attached Thumbnails Attached Thumbnails Optimum BF20 (G0704)  few ideas-img_0164-jpg   Optimum BF20 (G0704)  few ideas-img_0154-jpg
