Digits,
I tried using the G0 A90 in Mach 3 to rotate the 4th axis but I must be missing something somewhere,
it rotated and rotated like it was moving 90 inches.
I made sure the 'A-Axis is angular box was checked under Angular Properties but still nogo.
I got it working though.
I set the motor tuning up so the motor spun 1 rev per inch.
the stepper is a 1.8 deg/rev, 200 steps/rev at 1/8 microstepping.
set the A Axis motor to 2880 'steps per' at velocity of 40.
200 steps x 8 = 1600 x 1.8 = 2880 steps/rev.
Now when I program it, .25 in = 90 degrees, .5 = 180, .75 = 270 etc.
I made a little program to mill some wrench flats and the stepper held it great.
cut aluminum .050 deep at 25ipm and it didn't wiggle at all.
made a couple more programs to cut 6 and 8 flats.
wrote a program to mill a 16 tooth timing pulley. just took .015 at 10ipm per pass with .078 endmill.
Looked pretty good. no more buying them for me. used a 90 degree csink to break the edges.
I'll have videos up at Youtube here shortly.
http://www.youtube.com/hossmachine
I can program this way but would like to hear what I missed to use the G0 A90 etc. in Mach 3.
Hoss
