X2 cnc finished for now maybe - Page 51
Page 51 of 87 FirstFirst ... 4148495051525354 61 ... LastLast
Results 601 to 612 of 1034
Thread: X2 cnc finished for now maybe
  1. #601
    Gold Member hoss2006's Avatar
    Apr 2006
    Quote Originally Posted by X2cnc View Post
    I've been waiting for you to put a stepper up there and turn the swivel head into a fifth axis!
    You'd have to do B-axis motion by combining X and Z, though.
    As a CNC newbie I'm still not sure what I would use a 5th axis for.
    Maybe someday, but I don't need to make any impellers right now.
    "http://www.youtube.com/watch?v=0u2xC60-oMI"]5-Axis Impeller Blade
    It's already been done on a MaxNC.
    "http://www.youtube.com/watch?v=1EYaM4FkASA"]5-axis milling demo
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  2. #602
    Feb 2007
    Brunei
    Is the second machine cutting wood? Looks cool. But with the 5th axis, will it make the machine limited in terms of its capability in cutting harder metals like steel?
  3. #603
    Gold Member SpeedsCustom's Avatar
    Sep 2006
    Not if designed properly. You build some with low rigidity and obviously it can't handle but build and design it with strong rigidity and it will be ok.
    -Jason
  4. #604
    Registered SScnc's Avatar
    Jun 2008
    Quote Originally Posted by hoss2006 View Post
    Hey Gang,
    Finished my High Speed Spindle Motor attachment.
    Will use it mainly for engraving and grinding.
    Used a Dewalt Laminate Trimmer Model #DW670 I bought at Lowes.
    http://www.lowes.com/lowes/lkn?actio...670&lpage=none
    It has a 1/4 in. collet ( I made an 1/8 collet for it) and 34,000 rpm.
    Very nice quality item with no backlash in the spindle.
    Has a machined housing that fits nicely in the mount that I made to hold
    it perpendicular and true.
    Below are pics of the drawings and finished parts.
    The spindle is offset 3 in. from the X2 spindle on the X Axis as it's mounted here
    but it's able to mount on either side or the front.
    This should work well.
    Later Hoss
    P.S. As you can see I need to mount the Spindle Lock I made on the front yet,
    that's next.
    Hey Hoss,
    I need to add a high speed spindle to my X2 for making printed circuit boards and have a Rotozip that goes to 30,000 that I will use. I'm going to make an adapter based on yours and have a question.
    How deep did you tap into the bottom of your X2 head ? (I don't want to screw up anything inside)
    And would you mind providing the DXF for that part ?
    EDIT: For anyone else interested in this and would like to see the pictures, the above quote came from page 3, post number 28
  5. #605
    Dec 2004
    Memphis, TN
    Quote Originally Posted by SScnc View Post
    Hey Hoss,
    I didn't tap mine, I use the 3 existing screws that hold the bearing plate cover on. You want the DWG?
    Attached Thumbnails Attached Thumbnails X2 cnc finished for now maybe-new_mount_spindle-jpg
  6. #606
    Jun 2008
    Quote Originally Posted by Jay C View Post
    Yes, I would like to see the DWG file. Thank you very much, I appreciate it !
  7. #607
    Dec 2004
    Memphis, TN
    Attached. Note:, I drew my mount "on top" of the cad drawings another member did of the entire machine. I hid those layers, but they are still there IIRC.
    Jay
    Attached Thumbnails Attached Thumbnails X2 cnc finished for now maybe-new_mount_640-jpg
    Attached Files Attached Files
  8. #608
    Jun 2008
    Hi Jay,
    That's great ! I have all the toolpaths done for it, I just need to order some .750" 6106 stock. My X2 is a Grizzly with a MT3 spindle and is only ~.800" below the bottom of the head.
    Thanks again for taking the time to post and share this,very much appreciated,
    Steve
  9. #609
    Feb 2007
    Brunei
    Hi Hoss,
    I just got my new base from SIEG. As with yours, the new base is not the same as the one I am using. But the worst part is that the ways distance is 1mm shorter on the new base. What do you suggest I should do? Do you think using a 60 degree dovetail cutter to even out the difference would do the job? I know SIEG doesn't use 60 degree dovetail to cut the dovetail ways. I think its somewhere around 52 degrees.
    I was thinking of skimming all the dovetails to 60 degrees throughout just for uniformity. What do you think?
    Alex
  10. #610
    Apr 2006
    Do you have access to a machine big enough to cut the entire length of both bases?
    Skimming all the dovetails with the 60 could make it silkly smooth if it's accurate enough.
  11. #611
    May 2007
    If you haven't already, you might want to verify the runout on that spindle before doing too much work around it. In my experience, you can live with about .003-.005" of total error (backlash + runout) before it starts getting hairy with a typical board layout with features like signals between DIP pins. In the past, Rotozips and laminate trimmers would usually exhibit .005"+ TIR.
  12. #612
    Apr 2006
    My Dewalt Laminate Trimmer only had .001 runout, must have a good one
