X2 cnc finished for now maybe - Page 12
Page 12 of 53 FirstFirst ... 2910111213141522 ... LastLast
Results 221 to 240 of 1044
Thread: X2 cnc finished for now maybe
  1. #221
    Jul 2003
    Hoss, It in the Ports and Pins, Called Index. This is also used for threading.
  2. #222
    Jul 2003
    Default Spindle Index Mach3Mill
    OOP's, Forgot to add the pic.
    Attached Thumbnails Attached Thumbnails X2 cnc finished for now maybe-ports-jpg
  3. #223
    Dec 2004
    Memphis, TN
    Yep, that's the one. The one on the ShumaTech site is simpler and will work fine since the transistor is used in the saturated states.
    Jay
  4. #224
    Member hoss2006's Avatar
    Apr 2006
    Hey guys,
    thanks for the help.
    I found the original design for the belt conversion by Jerry Rollett on the
    GrizHFminimill yahoo group.
    download the pdf here.
    It's fancier than my rendition of it. Will require more detail work. Has a tach built in too.
    Hoss
  5. #225
    Gold Member acondit's Avatar
    Apr 2005
    Quote Originally Posted by hoss2006 View Post
    looks good Bob,
    similar to the one from Shumatech
    I have the parts SOMEWHERE.
    what port(input signal) would I need to hook up to in Mach 3?
    Thanks Hoss
    Hoss,
    Here is a tach setup I built. I used it with the DRO-350 to check the speeds that I am getting from the steppers with my manual driver.
    I originally built the board with the idea of using it for limit switches, but it works fine for a tach sensor as well. It has outputs for both NO and NC positions. It takes +5, gnd and signal connections. With the Shumatech DRO-350 I wired it to the NO position (close on pulse).
    Alan
    Attached Thumbnails Attached Thumbnails X2 cnc finished for now maybe-limitswitch1-c-jpg   X2 cnc finished for now maybe-limitswitch2-c-jpg   X2 cnc finished for now maybe-tach03-c-jpg   X2 cnc finished for now maybe-tach04-c-jpg
  6. #226
    Mar 2007
    Quote Originally Posted by acondit View Post
    Hoss,
    Alan
    Ok, where did you get the boards?
    Smitty
  7. #227
    Registered project5k's Avatar
    Sep 2006
    well the boards say "allan's machine works" on them.. im guessing he drew them up in some free software from the net, and then ordered them from one of thoes short run board making places on the net.. but thats just a guess...
    Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino.
  8. #228
    Apr 2005
    Smitty,
    Project5K is pretty close. I drew the schematics in Eagle but I actually laid out the board with Osmond Quartz (runs on the Mac). I am getting ready to offer them on my website. It took several runs to get the layout just right. It was the first board that I did totally myself and getting all the holes the right size was a new experience for me. Last time I was involved with a board design, was a larger board and I hired professionals to do all the layout. They make it look so easy. LOL
    Alan
  9. #229
    May 2007
    www.expresspcb.com has software and provide short run circuit board for relatively reasonable price and fast turnaround. there are cheaper option if you search the web though. (mostly out of china and batched, so it takes upto 30 days)
    small board like that will be easy to do multiple from expresspcb. (they have protoservice for $60 board for 3 -2.8x3.4 " board. you should be able to put at least 2 or 3 of those circuit on each board.
  10. #230
    Dec 2004
    Memphis, TN
    Seriously, that's way overkill for how simple this circuit is. You want a cheap "off-the-shelf" solution? Try this. At $14.95 it's a simple plug-n-play. But it's overkill, has a potentiometer to set the sensitivity ... used for line detection/following. All you need it the circuit shown on the ShumaTech site. No need for a PCB, just some resistors, the sensor, and some 3-lead cable to tie it back to the driver board or BOB if you use one, and some heat-shrink or electrical tape.
    Jay
  11. #231
    Sep 2006
    yea you could allways just go to the cellphone shack (sorry rat shack.. no no sorry "radio shack") hehe sorry used to manage a couple of them.. anyway, you could go there and get some of that perf board and build it on thoes, cut them to the size you need, and bingo....
  12. #232
    Jul 2003
    Default Sensor
    I used a telephone connection, to connect Mach3.
    Attached Thumbnails Attached Thumbnails X2 cnc finished for now maybe-1-jpg   X2 cnc finished for now maybe-2-jpg
  13. #233
    Aug 2006
    UK
    Quote Originally Posted by Bob Adams View Post
    Does that work well for you? I think I've recently read a post which said that using those connectors for servo-encoders was a bad idea as the error rate was pretty big...
  14. #234
    Jul 2003
    I have used the same telephone connector with my little pcb for a DRO encoder in machine shops. They didn't have any problems. I used capacitor to keep the +5 vdc up.
  15. #235
    Dec 2004
    Memphis, TN
    Quote Originally Posted by digits View Post
    If you had 1000ppr encoders then you might have issues, but 0-4000 rpm is a lot slower and thus 22ga wire would work fine.
    FWIW,
    Jay
  16. #236
    Apr 2006
    Thanks for all the tips guys.
    Here's 18 1/2 inches of X travel.
    The stock Z casting back is fairly flat. The largest variance on the Y is .001
    and .004 on the X Axis. The x dips in the middle down .003 on the front edge and rollercoasters on the back edge going down -.0015 in the center and up .0025 at the other end.
    i'll take .010 off with the surfacing cutter and all should be well.
    Then on to some Y fun.
    Hoss
    Attached Thumbnails Attached Thumbnails X2 cnc finished for now maybe-img_0321_800x600-jpg   X2 cnc finished for now maybe-img_0333_800x600-jpg   X2 cnc finished for now maybe-img_0334_800x600-jpg   X2 cnc finished for now maybe-img_0339_800x600-jpg
    X2 cnc finished for now maybe-img_0364_800x600-jpg
  17. #237
    Mar 2006
    Hoss,
    wow is that wild! But it looks like a lot of leverage on the small amount of dovetail when the table is fully extended. Any concerns about that?
    Steve
  18. #238
    Sep 2004
    Love the y-axis. very creative.
    Should be able got out a new saddle if you had to. To expand it's foot print a little bit.
    Either way, very nice.
  19. #239
    Apr 2006
    steve,
    i trust the guy running my mill won't put anything on it that's heavy enough to snap the dovetails.
    if he does, his a*s is mine!
    the pics show the extremes of travel, maybe for engraving something 18 in. long and lightweight.
    16 inches will keep the saddle being exposed and give the most strength.
    better than 8.
    hoss
  20. #240
    Dec 2004
    Memphis, TN
    Hoss, when you figure out how to expand the Y to 6" or more, you can quit your day job and open up shop
