X2 cnc finished for now maybe - Page 11
Page 11 of 87 FirstFirst ... 891011121314 21 61 ... LastLast
Results 121 to 132 of 1034
Thread: X2 cnc finished for now maybe
  1. #121
    Aug 2006
    u.s.a.
    Default motor on or off
    you can buy relays that will turn the motor on or off through mach. you just have to get one that ir rated at the amp &volts you need or higher &wire it to one of the out put pins that will put out 5 volts when activated. i have bought them on ebay for as low as $11.50 for 4. just type in solid state relays. i have one on my taig now. works great! greg
  2. #122
    Aug 2006
    u.s.a.
    i i just saw 2 soldstate relays on ebay the were @ $9.99 with no bid & 2 days 5 hrs to go, item # 300110632774. hope this helps you. greg
  3. #123
    Gold Member hoss2006's Avatar
    Apr 2006
    If only it were that easy.
    The X2 electronics that control the motor have safeguards built in that won't
    allow the motor to be turned on at higher speeds.
    Just like the treadmill controller I replaced my bad board with, "A motor controlled by this board must start at or near zero speed and then the potentiometer can be turned up for higher motor speed, the board will not allow the motor to be switched on at high speed."
    If power is cut, i.e. with a relay, the pot has to be turned off then back on to
    get the motor back up and running.
    I'm not gonna worry about it, it's easy enough to turn the knob without
    having the program do it for me.
    If i was doing some very long runs and wanted the program to turn the motor off when it was finished so I could walk away, a simple relay would do the job.
    Hoss
  4. #124
    Apr 2006
    Time for an upgrade.
    Ordered a 4-Axis Bipolar Stepper Driver Board from Xylotex today.
    Along with a new BIPOLAR STEPPER MOTOR 495 oz-in, 3/8” Diameter shaft with a flat KL23H2100-30-4B (Dual Shaft) from Keling Inc.
    Out comes the Stepperworld 3-axis unipolar driver.
    The bipolar driver will give me 278 oz/in from my old motors instead of 195 oz/in with
    the unipolar driver.
    That should give enough torque for the X and Y Axis' and for my 4th Axis.
    Replacing the Z Axis with the 495. Should drill through steel easier than before.
    Will jump up to 24 Volts too but not right away, want to see what I get for speed using 12 Volts first.
    If I'm happy, I'll save my $50.00.
    May have to change the Z Axis pulleys to 1:1 to increase the travel speed,
    the 495 is real torguey I guess but not fast.
    Ordered from Keling at 12 pm and got an email at 3pm saying it shipped already.Cool.
    later Hoss
  5. #125
    Oct 2005
    Hi Hoss
    To give you an indication I have the Xylotex board with one of their 24 volt supplies and run 495 oz motors on all three axes of my X2. I have the Homeshop nook ballscrews and get 47 IMP (1200mm/min metric conversion) on X and Y and these are direct coupled to the ballscrew. Z has a 2:1 reduction and I get half the speed.
    My observation is the 495oz motors are good for about 300RPM and then they drop off failry quick. I'm not sure if it is a drop in torque or they suffer from mid band resonance. Mind you in their working range they have heaps of grunt and easily drive the X2 head.
    Your conversion will give me a good comparison to my machine.
    Thanks for posting all your additions and modifiactions as I enjoy reading your adventures and it has opened my mind to what can be done with a CNC'd mill.
    cheers,
    Rod
    Perth, Western Australia
  6. #126
    Apr 2006
    Thanks Rod,
    Sounds like I made the right choices.
    The old unipolar 195 was just not getting the job done.
    I will save the old board for a lathe conversion or maybe a cnc router.
    I need to finish up the counter balance this weekend.
    Bought some Bondo to pretty it up. Will post some pics when I get it done.
    Later Hoss
  7. #127
    Jan 2007
    Whatever else you do, 24v is really the way to go, you won't believe the difference. Well worth the money. You can also get 24v supplies for a lot less than $50 too if you look to Ebay.
  8. #128
    Apr 2006
    Thanks steppermonkey,
    I bit the bullet and ordered a 24V 4.5 Amp power supply on Ebay for $28 w/shipping.
    As long as I have it all torn apart I might as well get it the way I want it now.
    Did find some nice power supplies at Circuit Specialists for $28-40 if anyone is looking for new ones.
    They have a 36V 4.2A for $40.75.
    Later Hoss
  9. #129
    Apr 2006
    The counter balance is ready to go.
    Made it pretty with some Bondo and paint.
    Can raise and lower the head with one finger now so the
    new 495 oz/in Z motor should have no trouble.
    Get a few more inches of travel now too.
    I did waste a little bit of good stock on it, got tired of cutting up rebar.
    Finally got around to wiring up the bandsaw blade welder from Harbor Freight.
    Now I can fix a bunch of broken blades, sometime.
    Never do today what can be put off till a week from thursday.
    Later Hoss
    http://www.hossmachine.com
    Attached Thumbnails Attached Thumbnails X2 cnc finished for now maybe-counter-balance-26_640x480-jpg   X2 cnc finished for now maybe-counter-balance-31_640x480-jpg   X2 cnc finished for now maybe-counter-balance-32_640x480-jpg   X2 cnc finished for now maybe-counter-balance-37_360x480-jpg
    X2 cnc finished for now maybe-counter-balance-39_360x480-jpg   X2 cnc finished for now maybe-bandsaw-blade-welder_360x480-jpg
  10. #130
    Apr 2006
    Have my new controller wired up and the bench test went perfect.
    Now that's more like it!
    Power Baby!
    The Xylotex 4 Axis Board was pretty simple to hook up especially since I now
    only have 4 wires from the motors (Bipolar) to deal with.
    24 Volts really gets them moving too.
    I played around with the motor tuning in Mach 3 to see how fast they could go.
    The old Stepperworld Unipolar driver wouldn't work at speeds above 20 ipm.
    The Xylotex worked at 70 ipm. Had almost no torque at that speed but it did
    get them a whippin.
    Probably set it at 50 ipm for rapids when it's on the mill but we'll see what it can take tomorrow.
    Later Hoss
    Attached Thumbnails Attached Thumbnails X2 cnc finished for now maybe-xylotex-4-axis-driver-8_640x480-jpg
  11. #131
    Jul 2004
    How much does that counter balance weigh? Looks like quite a bit of rebar in there.
  12. #132
    Apr 2006
    hey dropride,
    about 38 lbs. if my scale is any good.
    went by what little machine shop says the head assembly weighs.
    added a couple of nuts on the back to bolt more weight on if necessary to
    compensate for some of my attachments.
