X2 cnc finished for now maybe - Page 10
Page 10 of 53 FirstFirst ... 7891011121320 ... LastLast
Results 181 to 200 of 1044
Thread: X2 cnc finished for now maybe
  1. #181
    Oct 2006
    Hey Hoss,
    I'm totally addicted to this thread! I check it daily. That's never happened before. I did have a question about the 4th axis/lathe attachment you have created. What it the apparatus mounted to? Is it a flat piece of aluminum that replaces the x-y table? Is it mounted to the x-y table itself? Also, is the spindle that you used for the 4th axis/lathe movement stock or did you machine it yourself? I love the progress you are making, keep up the great work.
    Steve
  2. #182
    Dec 2004
    Memphis, TN
    Have a look at post 90 Pictures 1 and 2 should answer your question.
  3. #183
    Oct 2006
    Haha, it did. I'm an idiot.
    Steve
  4. #184
    Member hoss2006's Avatar
    Apr 2006
    Thanks guys for the kudos,
    Went down and played some more today.
    Tried some OD engraving with the 4th Axis.
    Took a little tweaking with the motor tuning to get it to cut the
    correct height but think i have it down now.
    The example below is supposed to have 1/2 tall letters, and it does now.
    I had my A Axis motor set at 2880 steps per rev which gave it 1 rev at the chuck or 1.0 in travel. 1/2 = 180 deg, 1/4 = 90 deg etc.
    After some trial and error with a wood dowel, the 1/2 in letters were taking up 180 degrees of the stock.
    To get it actually 1/2 tall I take the circumference of the part and divided that into 2880 to give me the new steps per rev for the motor tuning.
    For the part below .92 dia x 3.14 = 2.888. Divided 2880 by 2.888 = 997.2 for the motor tuning.
    Seems to work OK for my set up.
    I use Deskengrave to make the gcode. It's free.
    To trick the mill to use it for the A Axis, I opened the file with notepad, used "replace" to replace all the Y's with A's and saved the changes.
    now it rotates the A axis for the vertical lines instead of the Y axis. tada.
    probably an easier way out there and i'll look for it eventually.
    just havin fun playin and learnin now.
    Hoss
    The video will be up soon at youtube.
    Attached Thumbnails Attached Thumbnails X2 cnc finished for now maybe-4th-axis-od-engraving-test-2_800x600-jpg   X2 cnc finished for now maybe-4th-axis-od-engraving-test-4_800x600-jpg
  5. #185
    Jul 2004
    Hey Hoss, any update on the extended x&y you were working on?
  6. #186
    Apr 2006
    dropride,
    the main parts i needed are expected today from UPS.
    I still have to order some longer ballscrew on payday.
    Be a couple weeks before it gets rolling.
    Found another cheap source for the ballscrew at Reid Supply.
  7. #187
    Sep 2004
    Too cool. Love the 4th axis.
    It's definitely on my list of things to do when I get my conversion kit for x3.
  8. #188
    Apr 2006
    Should I let the cat out of the bag, I guess so.
    Here's a couple pics showing 20 inches of X-Axis travel. Does something look familiar?
    Still a ways to go.
    Have to fit the ballscrew, remount the motor and make a tooling plate.
    Then on to the Y-Axis.
    heehee.
    Hoss
    http://www.hossmachine.com
    Attached Thumbnails Attached Thumbnails X2 cnc finished for now maybe-img_0209_640x480-jpg   X2 cnc finished for now maybe-img_0210_640x480-jpg
  9. #189
    Registered ataxy's Avatar
    Jul 2005
    canada
    Quote Originally Posted by hoss2006 View Post
    Still a ways to go.
    heehee.
    Hoss
    did you use a z axis for the x axis
  10. #190
    Apr 2006
    aye, that I did. Arrgh.
    Sorry, watchin pirates of the Caribbean.
    16 inches of solid travel, 20 pushing it.
  11. #191
    Jul 2005
    canada
    i can bet you that you have just made LMS sell a few z collumn.
    wich one are you watching?
  12. #192
    Apr 2006
    ataxy,
    If you measure the x and z dovetails, you can see that it will require some massaging. Not too much though.
    Fitting the same ballscrew is going to be close without doing too much harm.
    switching to a smaller diameter screw would be easier, but that would be more money.
    Will find out how flat the back is ground compared to the dovetail, may need a resurfacing to true it up. Looks pretty good though.
    Have to get to making a belt conversion soon. Stripped the low gear out yesterday. oops.
    Attached Thumbnails Attached Thumbnails X2 cnc finished for now maybe-img_0165_640x480-jpg   X2 cnc finished for now maybe-img_0175_640x480-jpg
  13. #193
    Jul 2005
    canada
    well soon you will end up with a x2 the size of a knee mill
  14. #194
    Dec 2005
    wow, so how are u gonna mount the ballscrew, where is the screw gonna go without removing lots of material from the new x axis? i guess ill just have to see it!
    liek i said before u should get one of these: http://www.littlemachineshop.com/pro...ory=1687114045
    or take some design q's from it and build your own. its soooooooooooooo much bettter than the gears, and u can transmit so much more power!
  15. #195
    Apr 2006
    Quote Originally Posted by ataxy View Post
    You got that right.
    Actually I'll have 4 more inches of Y travel than the Bridgeports at work when I'm finished. gonna be a bit more work for that though.
    Skmetal7,
    Don't want to weaken the new X axis at the dovetail so the material came
    out of the saddle. The 5/8 ballscrew is gonna be tight, 3/8 would have been easier to deal with. too late now.
    if it cracks, back to the drawing board and spend more money.
    Attached Thumbnails Attached Thumbnails X2 cnc finished for now maybe-img_0232crop_402x480-jpg
  16. #196
    Member LongRat's Avatar
    Apr 2005
    UK
    Hoss,
    I noticed you are using the same method as I have been for programming the g-code for your rotary axis (find and replace all Ys for As). I'm having a problem because every time it makes an arc move (G2/G3) it goes completely off course. I think it has to do with the I and J values but I don't know if there is a setting in Mach to fix this. Have you changed something that makes it work for you?
    Nice work on the extended axis by the way
  17. #197
    Oct 2006
    Hey Hoss
    I had a question. I am a newbie to this stuff, and I am trying to figure it all out. I see that you have a DRO with scales on your machine. Does your DRO transmit data to Mach 3, or does Mach 3 compute it's own DRO based on the steppers number of revolutions per inch?
    Thanks!
    Steve
  18. #198
    Apr 2006
    longrat,
    I haven't tried using G2 or G3 yet with the a axis so can't help ya there.
    Grasshorse,
    The DRO is a standalone unit. I installed it before going CNC for manual use.
    I hardly use it at all anymore, maybe just to verify Mach 3 or set it to Zeros when I start a cut in case Mach 3 messes up or something crashes.Then I can get back to the start position.
    The new X Axis ballscrew fits now. I'm left with about 1/8 inch clearance.
    Need to make ANOTHER bracket now to tie it all together. Fun Fun Fun.
    Later Hoss
    Attached Thumbnails Attached Thumbnails X2 cnc finished for now maybe-img_0248_640x480-jpg   X2 cnc finished for now maybe-img_0253_640x480-jpg
  19. #199
    Dec 2005
    how in the heck are u gonna extend the y axis? are u gonna make your own dovetail and bolt it on? (maybe it has something to do with the bolt pattern he asked for...)
  20. #200
    Jul 2005
    canada
    i guess he will by extending the head foward but i am interested in seeing the amount of flex it will create in this machine as he extend and stretch the axis like he does
