Originally Posted by
lcvette
That's good news on the VFD!
Few things I noticed while going through mine in order to cure several of the vibration issues I had. The quill barrel casting was horrendously out of balance and a significant chunk of rotating mass to boot. I suggest chucking it in a lathe and at least turning it true in the out of balance areas, this helps alot at higher rpm but is negligible in stock form at low rpm.
Another concern was how the spindle cartridge is held in the headstock by the set screw. Because it's not a super tight tolerance fit and is designed to slide for quill operation, when you go straight CNC and tighten the set screw it is off center ever so slightly by the fit gap of the two parts. If you loosen that set screw slightly while running the spindle (be safe make sure it doesn't drop out) you can hear a change in the sound of the bearings.. quiets down when loosened and allowed to self center. I cleaned the headstock bore thoroughly and used some shim stock wrapped around the spindle cartridge to get it closer to concentric. Not an easy task as the shim stock likes to tear while installing but after a few tries it went in. This helped alot also.
My tapered roller bearings are very quiet, as much so as the AC bearings were at least, I don't think once you get everything sorted it will be a problem. My only big noise maker now is the cooling fan on the TEFC motor. Wish I had bought two of the 1.5hp inverter duty motors while they were available..Lol but it's not enough of a noise that I could justify what was what working great.!
I also replaced the upper will bearings which now run dead cool. For the vibration damper, I made the spindle pulley such that it puts fit into the quill barrel and the center bore was a snug fit to the spindle shaft. This does three things, it helps make the upper portion of the spindle shaft fully supported so it doesn't wobble, and it helps alleviate the spline engagement rattle. The last thing however is that it made the alignment of the Spindle cartridge and will barrel much more critical. Now that those things have all been addressed, my finishes and noise levels have never been better. If you take your time and follow suit I'm sure you will enjoy the same benefits!
Hope that helps!
