Sieg X2 metal gears?
Results 1 to 8 of 8
Thread: Sieg X2 metal gears?
    Nov 2015
    Default Sieg X2 metal gears?
    Hi, I am new here and just purchased a sieg X2 iln machine, we do have a lathe and I m planning to make metal gear and replace the plastic gears of the mill.
    Does anybody has a cross section or layout of the said gears? Thanks.
    Member hoss2006's Avatar
    Apr 2006
    Default Re: Sieg X2 metal gears?
    You can just buy the metal gears if you want to go the easy way.
    Metal Transmission Gear Kit, R8 Mini Mill 3449 - LittleMachineShop.com
    A belt drive would give you more rpm useful for soft material cutting also worth considering.
    Hoss
    Gosh, you've... really got some nice toys here. - Roy Batty -- [URL]http://www.g0704.com[/URL]
    Nov 2015
    My mini mill is MT3, and from my location, it will be costly to ship the gears.
    Apr 2006
    If you are interested there are free belt drive plans here you could adapt to your mt3 spindle, don't know if the top end is much different.
    Projects 6
    Hoss
    Nov 2015
    I have made the belt drive for the mini mill, the issue with us is the availability of the belt it self.
    Nov 2015
    Can someone share the dimension for this?
    Pics taken from the net.
    Sieg X2 metal gears?-480_3448-jpg
  7. #7
    Jun 2012
    Quote Originally Posted by toastedsiopao View Post
    Why? The plastic gears work as well if not better than metal gears.
  8. #8
    Nov 2015
    i just don't want to wait for the gears to break.
