Has anyone ever replaced the direction switch on a T23010 Power Feed?
Mine worked in both directions yesterday but only works in one direction today. I jumped the wires and can make the motor run in both directions so I guess it's a faulty switch. I'm not sure how hard they are to get or how expensive they are but I do want to get it fixed.
The wiring diagram on the installation instructions is a bit different than mine. I think this is because it shows a two button limit switch and mine only has a single button limit switch. There are a number of unused terminals on the direction switch and I thought perhaps they could be used to correct the problem. Has anyone ever tried this?
Hopefully this is an easy to get part and I won't have to try and make another style switch work in its place.
Any thoughts or advice would be great!
Thanks.
