Build Thread Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1 - Page 3
Page 3 of 3 FirstFirst 123
Results 25 to 33 of 33
Thread: Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1
  1. #25
    Registered Iron-Man's Avatar
    Jan 2009
    Default Re: Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1
    I had to change out the Denford tool post to a AXA style quick change tool post. Now I can follow the 15LSlant-Pro videos for tool offsets and set-ups. I am still looking for a suitable auto tool changer to modify for this lathe. Initial test cuts look promising. Initial diameter 0.3312 wanted 0.3151( Yaskawa SGMP motor shaft diameter), measured with micrometer 0.3153, delta = 0.0002.
    NovaTurn test cut
    AXA Style Quick Change Tool Post
    Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1-quick-change-tool-post800x600-jpg
    PathPilot Screen Initial Diameter 0.3312 reduce to 0.3151
    Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1-pathpilot-reading800x600-jpg
    Micrometer reading 0.3153, Delta = 0.0002
    Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1-micrometer800x600-jpg
    Pulley on shaft
    Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1-yaskawa-pulley800x600-jpg
    iBOB2 + GizmoSphere
    Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1-ibob-gizmo-1024x768-jpg
    Iron-Man
    Attached Thumbnails Attached Thumbnails Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1-quick-change-tool-post800x600-jpg   Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1-pathpilot-reading800x600-jpg   Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1-micrometer800x600-jpg   Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1-yaskawa-pulley800x600-jpg
  2. #26
    Jan 2009
    Sample test part. Will post more video later.
    Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1-tool-holder-2016-03-20-11-58-a
    Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1-part1-2016-03-20-jpg
    Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1-tool-holder-turret-2016-03-20-11-a
    Iron-Man
  3. #27
    Nov 2005
    us
    Items for Sale
    Is that an Emco turret that you will adapt to the Denford? I'm following this build with interest as well as Smokediver's Emco thread.
    I have a PC turn 55 (running on WinNC) and am about to take delivery of a 120 that will need a retrofit as the electronics are inoperable at the time and may not be salvageable. I have a Tormach mill too, so I would love to get them both working with PathPilot but know little about linuxcnc and its underpinnings.
    Would you be willing to share what you have learned about configuring Pathpilot lathe for other machines? I am super comfortable with the electronics and mechanical side of things, it is the software configuration on Linux that scares me.
    Keep up the great work!
  4. #28
    Jan 2009
    Quote Originally Posted by jcposada View Post
    Yes, it is a Emco turret. I am also doing the refit for Smokediver. Let me know if you want to upgrade to servos.
    Iron-Man
  5. #29
    Nov 2005
    us
    Items for Sale
    Quote Originally Posted by Iron-Man View Post
    Iron-Man
    For the big one, yes I think I will have to move to servos. For the little one, not unless that is the only way out. I believe the steppers and drivers that are currently in place can be made to work with a mesa card based on some threads I have seen on the linuxcnc forums.
  6. #30
    Jan 2009
    As promised, a short video of referencing the X and Z axes.
    Iron-Man
  7. #31
    Jan 2009
    Denford NovaTurn refit with AC servos.
    1/4 20 thread test with sample parts.
    Iron-Man
  8. #32
    Gold Member Fastest1's Avatar
    Nov 2009
    Nice job.
    I see you are running Path Pilot. Do you intend to have that tool changer front or rear mounted? If front mounted, do you see any issue setting up Path Pilot's tool page or format?
    I am just starting to learn LinuxCnc. I would enjoy using that kind of set up. There is plenty to learn there before that happens ;-)
    A lazy man does it twice.
  9. #33
    Jan 2009
    Quote Originally Posted by Fastest1 View Post
    Nice job.
    Thanks Fastest1
    I am looking at both options. Pathpilot uses a pwm signal to encode the tool number. I will be using a pic micro to decode this for a transparent interface to path pilot.
    Iron-Man
