Build Thread Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1 - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 13 to 24 of 33
Thread: Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1
  1. #13
    Registered Iron-Man's Avatar
    Jan 2009
    Default Re: Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1
    Quote Originally Posted by roschi View Post
    Hello Robert,
    you have send me an email but I can't respond your email adress...?
    Here is my answer to your question and your machine....
    Hello Robert,
    here you can download the used config:
    https://github.com/aschiffler/linuxc.../machine_cloud
    Perhaps it is difficult to understand. (perhaps erase all commented
    lines for a clear view)
    Here are some preconditions:
    - The drive for the A-Axis / Lathe-Main-Spindle can be switched from
    position control to speed control mode and vise versa
    - In my setup all drives have a digital field bus (ethercat); the
    communication is done via the module "lcec"; lcec.0.6 is the
    lathe-axis-drive.
    - To switch the Operation Mode lathe/A-Axis you "online" you have to
    unhome/home the a-Axis. (Therfore i have added some buttons in pyvcp,
    see vcp.xml)
    Hope that gives some hints to help you.
    The config 'machine_cloud' has add. data logger functionality; see video
    linuxcnc2cloud on my youtube channel for background.
    Regards
    Andreas
    Andreas thanks for the information. I am also currently working on a hardware/software solution that would have the spindle as default but switch to A-Axis when selected.
    I should be posting new pictures and video soon.
    Iron-Man
  2. #14
    Jan 2009
    I have been working on a design based on the iBOB2 and Gizmosphere 1. The Dimensions of the GQ1 are Width 6.79", Height 6.61" and Depth 10.29". It has 6 axis of +- 10V analog servo control and all I/O are available on 2 DB50 and 1 DB 25 connector. The RJ45 is for a pendant interface. It could also be made for step and direction. I prefer true closed loop control. I plan on selling the iBOB2 for anyone who wishes to make a ultra small CNC controller or place the complete controller within a small case or enclosure. The small circuit board in the back left is the iBOB2.
    Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1-gq1-jpg
    Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1-gq1back-jpg
    Iron-Man
  3. #15
    Jan 2009
    Initial testing.
    Iron-Man
  4. #16
    Oct 2012
    Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1-panel-png
    Where did you get this control panel from?
    -Dan
  5. #17
    Gold Member
    Jan 2005
    Quote Originally Posted by engnerdan View Post
    -Dan
    He built it. As in the pictures right above the one you linked.
  6. #18
    Oct 2012
    Quote Originally Posted by 109jb View Post
    Thanks but I am not that dense that, I can't see or read the posts. That was not what I was asking about, I want to know about the control panel he has mounted in his enclosure. I fixed my post so the picture shows up.
  7. #19
    Gold Member
    Jan 2005
  8. #20
    Jan 2009
    -Dan
    Dan I found it new, on ebay a few years ago. I am currently connecting the functions to a Mesa 7i77 card.
    The MPG and E stop were added later, also found new on ebay.
    Thanks,
    Iron-Man
  9. #21
    Jan 2009
    I have had to repair the encoder, it was faulty / defective. I have posted all the information that I could locate that might identify the encoder.
    It appears to be a 755A with a 10mm shaft with flat. In the Novaturn, only A and index are used.
    I modified my encoder to provide all signals, A A', B B', Z Z' which will be used for position control.
    I had to replace the ET7272B as it was faulty. I may modify the case to accept a 10 pin connector for quick disconnect.
    For those of you who might have a damaged or faulty encoder, please see the information below.
    I am currently designing a circuit to interface the Hardinge control panel to the MESA 7i77. This circuit will control the leds and membrane switches without using any additional I/O on the 7i77.
    Has anyone else looked at the Gizmosphere for CNC / control applications?
    I hope this helps,
    Iron-Man
    Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1-encoder-test-set-2015-09-29-21-a
    Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1-encoder-housing-1-2015-09-16-20-a
    Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1-encoder-housing-2015-09-16-20-37-a
    Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1-encoder-novaturn-2015-10-14-22-05-a
    Attached Thumbnails Attached Thumbnails Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1-et7272_a1-pdf   Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1-encoder-755a-shaft-pdf
  10. #22
    Jan 2009
    Default PathPilot on AMD Gizmosphere1, T40E + iBOB2
    I am almost finished. I have PathPilot running on the GizmoSphere 1.
    Specs:
    G-T40E dual-core processor running at 1.0 GHz, combined on a single die with AMD Radeon™ HD 6250 discrete-class graphics. The board provides a performance capacity of 52 gigaFLOPS (GFLOPS) at less than 10 watts. Custom high- and low-speed edge connectors enable a full range of functions. This unprecedented level of integration between serial and parallel processing offers a power-efficient foundation for high-performance multimedia content delivery across a broad range of embedded designs such as digital signage, x86 set-top box (xSTB), IP-TV, thin client, information kiosk, point-of-sale, casino gaming, media servers and industrial control systems.
    Currently decoding I/O on the Hardinge interface. The MPG, Axis select, and Rapid Override are functioning under Linuxcnc. I just need to change the bit file and 7i77 I/O for complete functioning.
    Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1-novaturn-2015-11-09-jpg
    Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1-hardinge-test-2015-11-09-jpg
    Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1-gizmosphere-1-pathpilot-2015-11-09-20-a
    Iron-Man
  11. #23
    Jan 2009
    Progress updates.
    Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1-surface-finish-jpg
    Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1-28-tpi-threads-test-jpg
    Iron-Man
  12. #24
    Jan 2009
    The Denford NovaTurn uses Inductive Sensors, BES 517-352-NO-L. I currently have them functioning in PathPilot. X and Z reference works correctly and also sets the soft limits.
    Will post video soon and use PathPilot to make initial test parts.
    Iron-Man
