wan tai d6560 setup
Results 1 to 2 of 2
Thread: wan tai d6560 setup
    Dec 2014
    Default wan tai d6560 setup
    i ve purchased wan tai d 6560 control board. the board works fine with mach3 , on old pc with xp os and built in printer port. my new pc was not having printer port ,hence i installed parallel port cable with db 25 port.the os system is xp.the dotmatrix printer works fine with new printer port but the wan tai control does not.all 4 l.e.d. indicator lights goes on as soon as i connect printer cable and power supply to the board.actually leds are indicators for 4 axis when they get signals from mach3.when i connect set up to old pc ,4 leds lights up only when i load g code in mach 3 and starts cycle..the ports and pins configuration on boath pcs is as per the wan tai catalog.
    kindly help me to solve this problem
    thanks in advance
    May 2013
    Gilligans Island
    Default Re: wan tai d6560 setup
    Buy a product called a 'smoothstepper usb', it fixes that. Those cheapo printer cables have to be full compliment DB25 but are usually only 3 or 4 pins.
    Wisdom results from foolishness!
wan tai d6560 setup
wan tai d6560 setup
