I would guess that if your code was configured to cut the cube all clockwise or all anticlockwise there will be two sides cut normally and two cut climb. If there is sufficient backlash in the Y axis then the cutter will pull or push the piece and so induce a degree of 'chatter'........well that's my theory!
