Hi Allhe means the plug is the wrong size
maximum diameter of 7.5mm that will be the plug it self not the pins
also you need one that's chemical resisting aswell
you will need one like this one M14-5 IP67 IP68 5Pin Waterproof Connector Cable Plug Socket Butt-Type: Amazon.com: Industrial & Scientific
may be bigger
I got the connectors. I installed them yesterday and ran a part on the machine. Not any problems at all. These connectors are nice for the price. I will be using the synthetic water coolant. and the only other chemical they will come in contact with is a very small amount of way oil Mobil #2. I tried both on the connector neither had any effect on the material. So I think they are good to go.
Hi Danielyall
Why is the size wrong? They seem to be working well?
CH
