Prolight 1000 Retrofit Newbie - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 14 of 14
Thread: Prolight 1000 Retrofit Newbie
  1. #13
    Oct 2014
    Default Re: Prolight 1000 Retrofit Newbie
    Located in Des Moines, IA.
    Took the cover off of the Z axis motors, they have the same technical markings as the others.
    Superior Electric
    Slo-Syn
    Type: m063-CS06
    Volts DC: 3.36
    Amps: 2.9
    200 Steps/Rev
  2. #14
    Apr 2013
    Quote Originally Posted by mhackney View Post
    I know the founder of Light Machines but he sold the company a few years ago.
    There is actually a lot of info, google it. I found this here: http://www.cnczone.com/forums/bencht...trol-card.html
    cheers,
    Michael
    Any chance he might still have some technical information on the servo controller used in the ProLight 2000 mill? I'd like to get it running in stock form with Linux CNC but without knowing any special commands it uses via the serial port... But that is a fortunate thing about the 2000, there's no separate box to get lost, just plug it to a PC with a single RS232 cable and it can be run off a DOS floppy or bootable USB stick.
    Sure would have been nice if the company had supported the PLM 2000 with their Windows software, but that only works with the stepper motor mills.
  3. #15
    Jun 2017
    I am a robotics coach in MI and the high school we are based in gave us some older light machine that are no longer used... I have a CNC router, a Prolight Mill and A Prolight Lathe..
    Also planning on converting to Mach3 and i should receive a gecko g540 drive today.
    I am looking at the CNC lathe and i am trying to figure out my wiring for the DB9 connector to the g540.... the stepper motors i have a are SLO-SYN stepping motors... M063-CS06 3.36V and 2.9 amps... g540 has great instruction but i am trying to figure out the wires from the motor....
    Any help would be appreciated.
    Seb
