I had some issues engraving plate, i found that the slight difference in material height made the fine engraving very inconsistent, so i designed a drill holder that is lightly spring loaded, works a treat , the depth now varies via speed, only pitfall is if you go over the same area twice it goes deeper every time. very happy with the results and will probably make a new one with a Collet style chuck.
