Home Made 4th Axis with Harmonic Drive Unit! - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 13 to 24 of 36
Thread: Home Made 4th Axis with Harmonic Drive Unit!
  1. #13
    Gold Member widgitmaster's Avatar
    Jun 2005
    Cool Now its time to make the fron fixture plate!
    The 4th axis will be able to use a 3" diameter 3-jaw scroll chuck, and a 1/2" thick cast iron t-slot fixture plate, for mounting irregular shaped blocks and parts.
    first I needed to use the 8" rotary table for my milling machine, then I took a scrap block of aluminum from the shelf and drilled 4 mounting holes and counterbored them. Then I mounted the plate to the rotary table with 4 3/8-16 SHCS and some t-Nuts that fit the rotary table.
    Attached Thumbnails Attached Thumbnails Home Made 4th Axis with Harmonic Drive Unit!-fixtureplate-jpg   Home Made 4th Axis with Harmonic Drive Unit!-000_0553-jpg   Home Made 4th Axis with Harmonic Drive Unit!-000_0554-jpg   Home Made 4th Axis with Harmonic Drive Unit!-000_0555-jpg
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
  2. #14
    Jun 2005
    Cool
    Then I took the two cast iron discs that I had turned to size on my lathe late last night, and used a 3/4" diameter 2-flute end mill to cut a pocket in the aluminum plate to nest the cast iron discs.
    Then I drilled and tapped two 1/4-40 holes at 22.5 degrees from the centerline of my milling table. These are for the two little straps to hold the discs in the nest.
    Attached Thumbnails Attached Thumbnails Home Made 4th Axis with Harmonic Drive Unit!-000_0555-jpg   Home Made 4th Axis with Harmonic Drive Unit!-000_0556-jpg   Home Made 4th Axis with Harmonic Drive Unit!-000_0557-jpg
  3. #15
    Jun 2005
    Cool
    Then I took a .1875 diameter carbide 4-flute end mill, and zeroed the end flush with the cast iron disc, then I plotted out my paths by cutting .002 deep where the slots will be.
    Two of the slots go completely across the disc, and four stop about 1" from center. this is to allow for the mounting holes to be drilled later.
    Then I set the depth of the endmill to .260", then I milled the 8-slots into the cast iron.
    Attached Thumbnails Attached Thumbnails Home Made 4th Axis with Harmonic Drive Unit!-000_0558-jpg   Home Made 4th Axis with Harmonic Drive Unit!-000_0559-jpg   Home Made 4th Axis with Harmonic Drive Unit!-000_0560-jpg
  4. #16
    Jun 2005
    Cool
    Then I changed cutters, and put a small t-slot cutter in the mill's collet.
    The cutter is .375" diameter x .125".
    I then followed the same path for all 8 slots, using the small t-slot cutter.
    Attached Thumbnails Attached Thumbnails Home Made 4th Axis with Harmonic Drive Unit!-000_0561-jpg
  5. #17
    Jun 2005
    Cool
    Next, I drilled 4 holed .5625" from center, around .192" diameter for a metric SHCS.
    Then I used a .315" diameter 4-flute endmill to cut the counter bore for the screw heads.
    Attached Thumbnails Attached Thumbnails Home Made 4th Axis with Harmonic Drive Unit!-000_0562-jpg   Home Made 4th Axis with Harmonic Drive Unit!-000_0563-jpg
  6. #18
    Jun 2005
    Cool
    Now we have a fixture plate that mounts on to the 4th axis harmonic drive unit. The same procedure was used to make a second disk.
    Total shop time: 3.5 hours each.
    Attached Thumbnails Attached Thumbnails Home Made 4th Axis with Harmonic Drive Unit!-fixtureplate-jpg   Home Made 4th Axis with Harmonic Drive Unit!-000_0507-jpg   Home Made 4th Axis with Harmonic Drive Unit!-000_0564-jpg
  7. #19
    Banned
    Dec 2003
    Very nice work.
    What is a harmonic drive?????
    Cheers,
    Colin
  8. #20
    Jun 2005
    Quote Originally Posted by yukonho
    Very nice work.
    Cheers,
    Colin
    Harmonic Drive: Technology for high precision high reduction gear.
    This drive has a 50 to 1 gear ratio.
    Eric
  9. #21
    Feb 2006
    Taiwan
    Default These are my stepper
    These are my stepper motor for you reference.Welcome to discuss with me mct.motor@msa.hinet.net
    Steven
    Attached Thumbnails Attached Thumbnails Home Made 4th Axis with Harmonic Drive Unit!-stepper-summary-jpg
  10. #22
    Gold Member dertsap's Avatar
    Oct 2005
    canada
    brillient !!!!
    nice to see a guy having fun !
  11. #23
    Registered RotarySMP's Avatar
    Mar 2004
    Vienna, Austria
    Nice work. Does that harmonic drive have any backlash?
    Regards,
    Mark
  12. #24
    Gold Member BobWarfield's Avatar
    May 2005
    Sorry to be late answering this last question. One advantage of harmonic drives is they have almost no backlash. There's quite a lot written about them on the Internet if you google. They come up pretty often on eBay fairly cheaply. Widgit's 4th axis is a nice compact design because of the harmonic drive.
    Best,
    BW
