Taking the head off will only shed about 60 lbs.
If you unbolt the column too that would break it up into manageable hunks by yourself, that's how I did it.
g0704.com pics
You'll need to check tram anyway but if you can lift the full mill as is with the help of a friend or two or use a hoist of some sort, tramming will easier.
Videos here on tramming Projects2
If you take the head off read #2 here. FAQs
Good luck, Hoss
