Homann Designs TM20LV (BF20,G0704) conversion - Page 25
Page 25 of 25 FirstFirst ... 1522232425
Results 289 to 300 of 300
Thread: Homann Designs TM20LV (BF20,G0704) conversion
  1. #289
    Registered CS900's Avatar
    Aug 2006
    Default Re: Homann Designs TM20LV (BF20,G0704) conversion
    Quote Originally Posted by phomann View Post
    You'd better hurry,my patent application is almost done.
    Cheers,
    Peter
    looks like i have a weekend project
  2. #290
    Registered phomann's Avatar
    Aug 2005
    Quote Originally Posted by Neptunes View Post
    Hey Peter so after speaking the wife had the same problem as you only 3mm but the ladies found iPad 2 cheap plastic covers in a 2 dollar shop and cut them up only thing was they only come in green, yellow, blue and red hope that helps I will check out the shop on Friday if they have any left will post on to you.
    Cheers
    Peter
    Thanks Peter. I'll have a look around as well. With all the LED displays around, I'd have expected that it would be easy to source.
    Cheers,
    Peter
    Homann Designs - http://www.homanndesigns.com
  3. #291
    Aug 2005
    Quote Originally Posted by photomankc View Post
    Ok, I am totally going to rip off the idea of putting that on the front of the mill. I just need need a spindle on/off and speed up/down buttons and maybe a start/abort. That would be awesome.
    The most difficult bit is lining up the existing mounting holes on the mill head. On my will they were all hand drilled on various angles. My backup plan was to drill new mount holes, hidden under the orange panel. For that though I'd have to take the mill head off the mill to use the drill press, otherwise they would be as out of alignment as the original ones.
    Cheers,
    Peter
  4. #292
    Aug 2005
    Quote Originally Posted by CS900 View Post
    I'll be doing some more over the weekend myself.
    Cheers,
    Peter
  5. #293
    Aug 2005
    Hi all,
    I was playing around with the new touch today. I made a new "short" cable to run to the socket on the front panel.
    https://www.homanndesigns.com/index....roducts_id=347
    Homann Designs TM20LV (BF20,G0704) conversion-probe_m-jpg
    Cheers,
    Peter
    Attached Thumbnails Attached Thumbnails Homann Designs TM20LV (BF20,G0704) conversion-probe_m-jpg
  6. #294
    Gold Member Fastest1's Avatar
    Nov 2009
    Nice addition. Does it disable the spindle once the probe is plugged in? ;-)
    A lazy man does it twice.
  7. #295
    Aug 2005
    Interestingly, as soon as I plugged the cable in, I thought "That's going to make a mess if the spindle starts!"
    No it doesn't. If I used a 4 pole connector on the PCB I could detect when the cable is plugged in, and with a bit of circuitry use it to disable the VFD.
    I'm not going to put the effort to design that in. Well not until I start the spindle with the probe in and wreck everything.
    Cheers,
    Peter
  8. #296
    Aug 2005
    Quote Originally Posted by Fastest1 View Post
    After a bit more thought on the matter, I'm going to add it in.
    Cheers,
    Peter
  9. #297
    Dec 2009
    Cheers,
    Peter
    Awwww, what fun is that!?! You're supposed to learn these things the hard way like I love to do.
    CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
  10. #298
    Nov 2009
    I like the fact he implemented a good idea that really started as a joke. Safety if cheaply attainable is best. I might even be a consumer of another of his products ;-)
  11. #299
    Dec 2009
    Yep, and the safety interlocks you don't have to think much about are the best kind. That's why I like this site. I'd likely never think of that either until a mishap enlightened me.
  12. #300
    Jun 2011
    I think there are also 1/8" jacks with a switch on them to mechanically detect when something is plugged in. They're what laptops and cell phones use to mute the speakers when you plug your headphones in.
