I used the text function in Sheetcam to produce the G-Code. The text height is 6mm.
After I engraved the the first 3 flats (every 2nd flat) I realised that the 6 and the 9 could be confusing, so after I engraved the second three with the dot, I added the other tree dots in manually.
